CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: Mark on April 24, 2015, 09:10:30 AM
According to the Help ....
To Export Maps to AutoCAD
3. Click Output tabMap Data Transfer panelSave Current Map To AutoCAD. Find
4. In the Save Current Map To AutoCAD wizard, do the following:
I can no longer see the 'wizard'. *shrug*
anyone know why?
is it this command?
_AeccExportToSDF
is it this command?
_AeccExportToSDF
nope! its _mapexportcurrentmaptodwg
ah...._mapexportcurrentmaptodwg
I don't get any WIZARD either I don't think it actually exists...sort of like "The Wizard of Oz" there is no wizard
let me see if there is some other way to summon this reluctant wizard...
interesting and notable NO image of this 'wizard' is shown on help file pages....hmmmm
oh but it does! I have seen the mighty wizard.
of all the times I have exported MAP to DWG I have never seen the wizard...ever
and NOW I know why.....I use MAP inside C3D....
However IF I launch MAP from Programs>>>Autodesk>>>Map ver Num.....THEN I do get the Wizard
so like WOW one MUST be in MAP for the MAP Wizard to appear!!!!!!
because you know, MAP inside C3D isn't really MAP! (I guess???) :uglystupid2:autodesk :idiot2:
LOL
i was just going to try the very same thing.
LOL
did I ever say how much I love autodesk??? :tickedoff: :tickedoff: :tickedoff: :tickedoff: :tickedoff: :tickedoff: :tickedoff:
It will work in Civil 3D if you add the support map of Map to the search path. Autodesk forgot that.
Which one?
just add all of them for good measure...
What you see is what I have already. Where are the others?
here are the paths from MAP
Be aware that you are using differing builds of Map.
that would be why I removed most references to version number
