Author Topic: This lisp creates itself with the dwg in the same folder  (Read 11824 times)
HasanCAD
Re: This lisp creates itself with the dwg in the same folder
« Reply #15 on: October 18, 2010, 05:56:16 AM »
GENERAL COMMENT :
I am less than you in the securety, may be because of my gluttony of learning
But for this file I didnt load this file but loaded automatically when open any dwg
I would have been able to solve this immediately.
I appreciate your help.
So, there is a lesson in that regard as well  :)
It is good lesson
« Reply #16 on: October 18, 2010, 05:58:29 AM »
GENERAL COMMENT :
You must have got the file from SOMEWHERE .. do you know where ?
HasanCAD
« Reply #17 on: October 18, 2010, 06:04:49 AM »
this is habben when we open any cad file for a project we working on
It's a bridge project comes from a consultant company located in US.
« Reply #18 on: October 18, 2010, 06:12:09 AM »
Well, you'd better tell them that they are distributing a virus.
Point them to this thread if necessary ....
HasanCAD
« Reply #19 on: October 18, 2010, 06:26:36 AM »
There is no way to protect our system from coping this file
May be they dont have a solution
May be they don know that they system is infected
ny the way I searched for this file and found but in chines language (I think that)
see this
http://www.google.com.eg/search?q=basepath+baseacad+acaddocpath++r-acaddoc+w-basepath+rl-acaddoc++acaddoclsp++c-acaddocname&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&oe=&redir_esc=&ei=byC8TN_-I8q6jAeL9disDg
« Reply #20 on: October 18, 2010, 06:34:38 AM »
I meant search YOUR machines and server, not google , sorry for confusion :)
Are you working from their server or yours ??
You need to DELETE the incorrect files. ... simple as that ... then add a good file to the ACAD.EXE folder.
HasanCAD
« Reply #21 on: October 18, 2010, 07:11:55 AM »
There was no confusion, I searched my machine and delete that file.
But while I am on net I made that search.
We working from our server,
Let me tell you from the beginning
Our system was ok,
We received cad files related to a project
Automatically this lisp file created in the same path of the opened file when we open any file related to this project,
After that the infection attack the AutoCAD itself and this lisp created at the same path of opened file.
So I am search for a solution for that
« Reply #22 on: October 18, 2010, 07:26:47 AM »
You already have the solution :
And ensure that next time you get files from the client the "acadDoc.Lsp" file is NOT included with the files.
Don't forget to search ALL machines in your office because the code you posted copies the file from the DWG folder back to the ACAD.EXE folder.
HasanCAD
« Reply #23 on: October 18, 2010, 07:27:10 AM »
Thanks for deleting the infected file
« Reply #24 on: October 18, 2010, 07:28:11 AM »
My pleasure :)
« Reply #25 on: October 18, 2010, 10:59:15 AM »
Its pretty badly written, but it does rely on you having an ACADDOC.lsp already on the system to duplicate - tbh I've seen worse code of this type specifically engineered to create multiple ACADDOC.lsp's to change Sys Vars and Registry Values  :|
Still - not nice, and I agree with Kerry's sentiment about understanding (at least partially) the code you are about to run.
