Author Topic: Question about selecting an object from a point  (Read 5694 times)
Re: Question about selecting an object from a point
« Reply #30 on: January 07, 2011, 07:10:47 AM »
I'm not going to waste my time looking at a drawing with a couple of thousand entitys in it and no description of what you are trying to achieve.
please post a simple example of what you are trying to do.
Brick_top
« Reply #31 on: January 07, 2011, 07:18:19 AM »
This was the drawing in which I was doing the tests since I thought I didn't have to use any specific drawing to test it.
I was expecting to select the next object the routine would found in the -x direction from the picked point.
The real usage I wanted it for is already working, which as for it to select a closed polyline surrounding the picked point.
I'm really sorry if I made some confusion because of being too vague and not giving the correct information and wasting your time
« Reply #32 on: January 07, 2011, 07:26:12 AM »
I surpose there's a lesson there for all of us.
I'm pleased you have what you want.
OFF TOPIC :
I don't think your client will get those cars out of the garage  :-)
Brick_top
« Reply #33 on: January 07, 2011, 09:17:44 AM »
Thanks for your patience!
yeah it will be hard to get the cars out, I'm working on it still
