Author Topic: REMOVE aecc_TIN_SURFACE from AutoCAD DWG.  (Read 2617 times)
jpcadconsulting
« on: December 01, 2015, 03:57:21 PM »
Hi gang,
I'm using AutoCAD 2014
I have received drawings with an aecc_TIN_SURFACE object. (From civil3D I assume)
I can't get rid of it.
AECTOACAD does not do the trick. (nor of course does trying to delete, explode, burst it, etc.)
The best I can do is use QSELECT to select it and move it to a frozen layer so we can't see it (PROXYSHOW has no effect).
Any help is appreciated.
Technology will save us all! *eyeroll*
Re: REMOVE aecc_TIN_SURFACE from AutoCAD DWG.
« Reply #1 on: December 01, 2015, 04:09:42 PM »
Post your drawing.
jpcadconsulting
« Reply #2 on: December 01, 2015, 04:30:53 PM »
Oops.  Here you go.
« Reply #3 on: December 01, 2015, 04:36:31 PM »
PROXYSHOW = 0 works for me .. but I'm in vanilla cad.
jpcadconsulting
« Reply #4 on: December 01, 2015, 04:39:37 PM »
Odd.  PROXYSHOW is set to 0 and it still shows up.
Thanks for your help.  I'll post if I find a solution.
« Reply #5 on: December 01, 2015, 04:42:16 PM »
Looks like it's missing an XML file in Civil 3D maybe someone else can chime in sorry.
Maybe? http://beingcivil.typepad.com/my_weblog/2013/06/why-i-cannot-delete-surface-from-prospector.html
jpcadconsulting
VovKa
  • Ukraine
jpcadconsulting
« Reply #8 on: December 01, 2015, 05:50:44 PM »
Thanks!!! I'll try that now.
I did find that saving the file as a 2013 DXF and then reopening resolved the issue as well.
I working LISP will be much easier though...
Jeff_M
  • C3D user & customizer
« Reply #9 on: December 01, 2015, 06:03:30 PM »
The surface was 'locked' in Civil3d, this is often done to prevent it from accidentally being edited. Unlocking it allowed it to be erased.
