CAD Forums > CAD General
BAK files
(1/1)
morpheus:
Hey, i want all the .bak files to be nested in one folder, i tried using the 'movebak' command, but it seems to only apply to the drawing you're currently working on, i want all drawings i work on to automatically move their respective .bak files to a separate folder i choose
Peter2:
Maybe you could ask in one of the "coding-forums" here (Lisp, .net), or you are trying an external software, e.g. made with https://www.autohotkey.com/
dexus:
Movebak should be persistent from when it is set. Are you sure the .bak files that are in the wrong location aren't from before changing it or maybe from colleagues?
57gmc:
I can confirm that MOVEBAK is a global command. It applies to all dwgs that YOU work on. Others may not have MOVEBAK set. If you want the whole office to standardize, you could add the command to acad.lsp. I have code that monitors the folder specified by the MOVEBAK command and deletes files older than the specified period.
Navigation
[0] Message Index
Go to full version
