(defun uservalues (/ saved_values)
(setq saved_values
'(("Val1" value1)
("Val2" value2)
) ; ends list of values
); ends setq
) ; end defun
(defun c:TEST (/)
(setq value1 "10.22")
(setq value2 "99.99")
(uservalues)
I'm struggling with applying a defined value and sending to a list. The list does not reflect my desired results. I've never been good with bound and local variables. Suggestions?
Undesired result =(("Val1" VALUE1) ("Val2" VALUE2))
Desired result =(("Val1" 10.22) ("Val2" 99.99))
