Author Topic: icons  (Read 6233 times)
Atwist
icons
« on: August 26, 2012, 12:38:35 PM »
Does anyone know where the icons are from autocad
Re: icons
« Reply #1 on: August 26, 2012, 12:54:13 PM »
They are compiled into a DLL. There is a thread here about it.
I'll look later.
http://goo.gl/P7aXi
« Last Edit: August 26, 2012, 12:59:27 PM by CAB »
Atwist
Re: icons
« Reply #2 on: August 26, 2012, 01:14:12 PM »
Thans CAB,
Re: icons
« Reply #3 on: August 26, 2012, 03:15:07 PM »
This thread may be of interest.
Rod
Re: icons
« Reply #4 on: August 26, 2012, 10:32:05 PM »
If you copy acadbtn.xmx and rename the copt it to acadbtn.dll you can open it with a program such as reshacker (free download) and save the images.
These are the images from the toolbar icons
"All models are wrong, some models are useful" - George Box
Re: icons
« Reply #5 on: August 26, 2012, 11:36:04 PM »
BlackBox
Re: icons
« Reply #6 on: August 27, 2012, 01:30:16 AM »
Depending on what version you have, you can also replace the splash image in AcadRes.dll using something like ResHacker.
I use IcoFx (there's also a portable apps version) to extract images from compiled files such as dll, exe, etc.
Atwist
Re: icons
« Reply #7 on: August 27, 2012, 04:45:16 AM »
How can I save the image because I do not see any image.
 I acadbtn.xmx copied and renamed acadbtn.dll it reopened with resource hacker.
 Get codes than just seeing.
00231FB0  00 00 01 00 02 00 10 10 00 00 01 00 20 00 68 04   •••••••••••• •h•
00231FC0  00 00 26 00 00 00 20 20 00 00 01 00 20 00 A8 10   ••&•••  •••• •¨•
00231FD0  00 00 8E 04 00 00 28 00 00 00 10 00 00 00 20 00   ••Ž•••(••••••• •
00231FE0  00 00 01 00 20 00 00 00 00 00 40 04 00 00 00 00   •••• •••••@•••••
00231FF0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ••••••••••••••••
00232000  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ••••••••••••••••
00232010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ••••••••••••••••
00232020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ••••••••••••••••
00232030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 1B   •••••••••••••• •
00232040  22 FF 19 15 1A FF 0F 0C 10 FF 32 29 23 FF 0F 0C   "ÿ•••ÿ•••ÿ2)#ÿ••
00232050  0F FF 5D 4B 40 FF 28 21 1D FF 08 07 06 FF 01 01   •ÿ]K@ÿ(!•ÿ•••ÿ••
00232060  01 FF 08 07 06 FF 28 21 1D FF 5D 4C 41 FF 65 52   •ÿ•••ÿ(!•ÿ]LAÿeR
00232070  45 FF 32 29 23 FF 13 10 15 FF 1B 16 1D FF 26 1F   Eÿ2)#ÿ•••ÿ•••ÿ&•
00232080  28 FF 77 64 56 FF A7 93 80 FF 32 29 23 FF 5B 4A   (ÿwdVÿ§“€ÿ2)#ÿ[J
00232090  3E FF 0C 0B 09 FF 26 21 1C FF 7E 6F 5F FF B3 9D   >ÿ•••ÿ&!•ÿ~o_ÿ³
002320A0  86 FF B3 9D 86 FF F8 D1 A2 FF 27 22 1D FF 5D 4B   †ÿ³†ÿøÑ¢ÿ'"•ÿ]K
irneb
Re: icons
« Reply #8 on: August 27, 2012, 05:50:57 AM »
Don't know about recourse hacker. I've used XN Resource Editor in the past. Just checked with my PortableApps version of it. Don't need to rename to a DLL, can open the XMX file directly and results in something like this:
Atwist
Re: icons
« Reply #9 on: August 27, 2012, 08:56:51 AM »
I'm now using XN Resource Editor Vresion 3.0.0.1 but the lamest thing I have no image option see below.
 So I really do not see image
irneb
Re: icons
« Reply #10 on: August 27, 2012, 09:14:08 AM »
That's because the portion you're looking at is listed inside the XMX file as a raw data item. Not as an icon or bitmap.
You can still use XN to extract that. Use it's Resource --> Export Resource menu, then saveas to an ICO file. It seems to work fine for me. With these "raw" resources you don't necessarily know in what encoding they are, so you may have to do some trial-n-error with the extensions like BMP/ICO/GIF/etc.
Atwist
Re: icons
« Reply #11 on: August 27, 2012, 09:39:08 AM »
Thanks Irneb,
That works
irneb
Re: icons
« Reply #12 on: August 27, 2012, 10:48:07 AM »
You're welcome, glad you got it working.
highflyingbird
  • Later equals never.
Re: icons
« Reply #13 on: August 29, 2012, 08:34:11 PM »
Here is my  program and my demo:
To see the detail ,look at
this topic
« Last Edit: August 29, 2012, 09:19:30 PM by HighflyingBird »
I am a bilingualist,Chinese and Chinglish.
Atwist
Re: icons
« Reply #14 on: August 30, 2012, 03:27:27 AM »
Hello HighflyingBird,
 Lee had already pointed this out but I had not yet checked.
 But this is very nice and much easier than the other programs.
Great
 Thank you for this tool
