Author Topic: Layer State name doesn't show in dialog box  (Read 2453 times)
Matt__W
  • I like my water diluted.
« on: November 13, 2008, 11:11:29 AM »
I've got this snippet of code that will create a layer state called "Temp_Layer_State" but it doesn't show up in the Layer States dialog box.  It's in the dictionary and I get a 'duplicate key' error if I try to create again so it does exist.  Anyone know the trick to getting it to show up in the dialog box?
Public Sub LS()
    Dim objLSM As AcadLayerStateManager
    Set objLSM = ThisDrawing.Application.GetInterfaceObject("AutoCAD.AcadLayerStateManager.17")
    objLSM.SetDatabase ThisDrawing.Database
    objLSM.Save "Temp_Layer_State", acLsAll
    Set objLSM = Nothing
End Sub
Autodesk Expert Elite
Matt__W
Re: Layer State name doesn't show in dialog box
« Reply #1 on: November 13, 2008, 11:19:15 AM »
Well this is odd.  Instead of using 'acLsAll' I used the code below and now it shows up in the dialog box.  Huh.  :?
Public Sub LS()
    objLSM.Save "Temp_Layer_State2", [color=red]acLsColor + acLsFrozen + acLsLineType + acLsLineWeight + acLsLocked + acLsNewViewport + acLsNone + acLsOn + acLsPlot + acLsPlotStyle[/color]
End Sub
Spike Wilbury
« Reply #2 on: November 13, 2008, 11:33:24 AM »
Matt,
As far as I recall / know  - that's a known bug.
Matt__W
« Reply #3 on: November 13, 2008, 11:34:00 AM »
Matt,
Ah... that would explain it!
Thanks!
