Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Artisan on October 15, 2004, 01:44:16 PM
I am having trouble with my lisp routine for a copy then rotate command I use. When I select the object to copy, it copies the object, allows me to place the copy where I need it and then when it rotates, it will rotate the original object instead of the copy. Here's the routine:
(DEFUN C:cR (/ SS P1 P2)
(PRINC "\nSelect objects Rob :")
(setq ss (ssget))
(if ss (progn
(setq P1 (getpoint "Basepoint :"))
(setq P2 (getpoint "Destination :"))
(command "COPY" ss "" P1 P2 "")
(command "rotate" ss "" P2)
Here's the one I use...
;;COPYROT.LSP Copyright 1998 HyperPics all rights reserved
;; Author: Lee Ambrosius,
;; HyperPics
;; http://members.aol.com/HyperPics/Home.html
;;COPYROT is a command to allow you to copy an object and then do
;;a rotate right after it. Once loaded just type in COPYROT to activate
;;the command.
;;This is a great file to place inside of your ACAD.lsp file or use
;;it by itself.
;; All documentation must stay with this Lips routine though.
;; Find and give me the Group nams in a lists
;; First string in list will be the last group created
(defun newgroups (/ GRPS OD GRP1 CHCKR GRPS GNAME)
(setq OD (namedobjdict))
(setq GRPS (dictnext OD "acad_group"))
(while (/= CHCKR 3)
(setq GRP1 (car GRPS))
(setq GRPS (cdr GRPS))
(setq chckr (car GRP1))
(if (= chckr 3)
(setq NGROUPS (list (cdr GRP1)))
(while (/= GRPS nil)
(if (= chckr 3)
(setq GNAME (cdr GRP1))
(setq NGROUPS (cons GNAME NGROUPS))
(setq EXGNAME (car NGROUPS))
;;Error Tile
(defun MYERROR (S)
(if (/= S "\nFunction cancelled" )
(princ "\nEnding Copy Rotate..." ))
(command "-group" "e" "copier")
(command "undo" "end")
(command "u" "u")
(setvar "CMDECHO" CMD)
(setq *ERROR* OLDERR )
;; Main section of Copy Rotate
(defun c:COPYROT (/ SS1 PT1 PT2)
(setq SS1 nil)
(setq CMD (getvar "CMDECHO"))
(setq OLDERR *ERROR*)
(setq *ERROR* MYERROR)
(command "undo" "begin")
(setvar "CMDECHO" 0)
(prompt "\nSelect Objects to Copy-Rotate: ")
(setq SS1 (ssget))
(command "-group" "" "copier" "" SS1 "")
(setq PT1 (getpoint "\nFirst Point of displacement: "))
(prompt "\Second Point of Displacment: ")
(command "._copy" "g" "copier" "" PT1 pause)
(setq PT2 (getvar "LASTPOINT"))
(prompt "\nSelect Angle of Rotation: ")
(command "._rotate" "last" "" PT2 pause)
(newgroups)
(command "-group" "e" EXGNAME)
(redraw)
(prompt "\nCopy Rotate complete....")
) ;; End of Copy Rotate
(c:COPYROT)
i got this one from someone here i think which contains both move and copy rotate
(defun c:mr () (b-cmr "M")(princ))
(defun c:cr () (b-cmr "C")(princ))
; File : mcr.lsp
; Date : 20-9-03
; Function : (B-CMR <MODE>)
; Purpose : Copy+Rotate or Move+Rotate
; Arguments : <MODE> = "C" -> Copy-rotate
; = "M" -> Move-rotate
; Written by : J.J.Damstra
(defun b-cmr (typ / ss1 temp p0 p1)
(setq ss1 (ssget "I"))
(command ".undo" "begin")
(setq temp (getvar "CMDECHO"))(setvar "CMDECHO" 0)
(if (not ss1)(setq ss1 (ssget)))
(if ss1
(initget 1)
(setq p0 (getpoint "\nBasepoint : "))
(if (= typ "C")
(setq p1 (getpoint "\nTranslation or <ENTER>: " p0))
(if (not p1)(setq p1 p0))
(command ".copy" ss1 "" "0,0" "0,0")
(while (not p1)(setq p1 (getpoint "\nTranslation : " p0)))
(command ".move" ss1 "" p0 p1)
(command ".rotate" ss1 "" p1 pause)
(princ "\nMsg> Nothing selected! ")
(command ".undo" "end")
(setvar "CMDECHO" temp)
Ok fellows, I have used the the following routine and I have one problem with it. Now when I open a drawing, the Copy-Rotate command starts as soon as the drawing opens.
(defun c:CR (/ SS1 PT1 PT2)
(setq SS1 nil)
(setq SS1 (ssget))
(newgroups)
(redraw)
(c:Cr)
I believe it's because of (c:Cr) at the end of your code. Remove it or comment it out. ;;;
If the problem is that it runs upon loading then remove the line that invokes the command; the last line (c:CR)
Oh, hi Daron :)
Hey, Stig.
Good Deal, that worked. Thanks
Ok, new problem now. I am using the lisp routine and all of a sudden I am getting this error:
Command: CR
Select objects: 1 found
Select objects:
<Selection set: 6>
; error: Function cancelled
Anyone seen this?
How about this?
;; Copy Rotate a selection set
(defun c:cr (/ usercmd ss1 pt1)
(setq usercmd (getvar "CMDECHO"))
(if (and (setq ss1 (ssget))
(> (sslength ss1) 0)
(setq pt1 (getpoint "\nFirst Point of displacement: "))
(command "._copybase" pt1 ss1 "")
(command "._pasteclip" pt1); replace originals
(command "._move" ss1 "" pt1 pause)
(command "._rotate" ss1 "" (getvar "LASTPOINT") pause)
(prompt "\nUser Quit....")
(setvar "CMDECHO" usercmd)
Good deal, it works for the time being. Thanks
