Author Topic: Commercial Tools for. NET  (Read 11364 times)
exmachina
Gizmox Visual WebGui Professional Studio
« Reply #15 on: August 31, 2013, 01:02:00 AM »
With its familiar .Net visual drag n' drop, WYSIWYG designer and  HTML5 rendering engine, Visual WebGui is the natural choice for core Visual Studio developers who want to create native quality, cross-platform enterprise level HTML5 apps in VB.NET or C#.
Home:
http://www.visualwebgui.com/Gizmox/Solutions/VisualWebGui/VisualWebGuibHomepageb/tabid/801/Default.aspx
« Last Edit: August 31, 2013, 01:29:11 AM by jar »
exmachina
CodeRush
« Reply #16 on: August 31, 2013, 01:05:15 AM »
CodeRush
CodeRush makes it easier to see what's going on with complex code, so you can move forward and spend less time wandering and wondering. Why is that expression's value different from what you expect? When did that local change? How many times have we been through this loop? CodeRush's compelling new debug visualizer effortlessly and instantly answers these questions and more.
Very good.
Home:
http://www.devexpress.com/Products/CodeRush/
« Last Edit: August 31, 2013, 01:28:38 AM by jar »
exmachina
DocToHelp
« Reply #17 on: August 31, 2013, 01:14:36 AM »
DocToHelp
Help and documentation software (.pdf, .chm, web help, Visual Studio Help... and others)
It work very well with .doc files
Home:
http://www.doctohelp.com
« Last Edit: August 31, 2013, 01:27:25 AM by jar »
exmachina
Help & Manual
« Reply #18 on: August 31, 2013, 01:19:03 AM »
Help & Manual
It work very well, but it can not import .doc files (can import the RTF files)
Home:
http://www.helpandmanual.com/
« Last Edit: August 31, 2013, 01:26:24 AM by jar »
exmachina
VSdocman
« Reply #19 on: August 31, 2013, 01:23:32 AM »
VSdocman
Visual Studio code commenter and documentation generator
Home:
http://www.helixoft.com/vsdocman/overview.html
exmachina
Submain GhostDoc pro
« Reply #20 on: August 31, 2013, 01:25:30 AM »
GhostDoc is a Visual Studio extension that automatically generates XML documentation comments for methods and properties based on their type, parameters, name, and other contextual information.
Home:
http://submain.com/products/ghostdoc.aspx
CADbloke
  • Crash Test Dummy
Atomineer
« Reply #21 on: September 01, 2013, 09:48:02 PM »
Another piad tool for code documentation, similar to Ghostdoc, to add to this list: http://www.atomineerutils.com/. I use it and like it.
exmachina
InstallAware
« Reply #22 on: September 12, 2013, 07:51:44 PM »
InstallAware
Software installation solution for Windows
Home:
http://www.installaware.com/
starting at €999 ...it is not cheap
exmachina
Advanced Installer
« Reply #23 on: September 12, 2013, 07:55:05 PM »
Advanced Installer
Home:
http://www.advancedinstaller.com/
Start at $299 (without dialog editor)
exmachina
StickyNotes4Code For Visual Studio
« Reply #24 on: September 12, 2013, 07:59:10 PM »
It is a Visual Studio plug in that seamlessly integrates with the IDE providing sticky notes capabilities to documents within a solution. While several methods exist for lightweight code review, such as "over the shoulder" reviews, review by email and meetings, the most effective reviews are conducted by tools to facilitate the process.
Home:
http://www.stickynotes4code.com/
Note: only fo VS professional or upper
exmachina
Tabs Studio
« Reply #25 on: September 12, 2013, 08:01:06 PM »
Tabs Studio
Tool to organize and customize Visual Studio document tabs.
Home:
http://www.tabsstudio.com/
Note: only for VS professional or upper
exmachina
VisualSVN
« Reply #26 on: September 12, 2013, 08:05:58 PM »
VisualSVN
Subversion integration plug-in for Visual Studio.
Home:
http://www.visualsvn.com/visualsvn/
Free Community License:
VisualSVN Community License is a free of charge license that allows to use VisualSVN on any computer which is not a member of an Active Directory domain
exmachina
XAML Spy
« Reply #27 on: September 12, 2013, 08:08:19 PM »
XAML Spy
Is a visual runtime inspector for Silverlight, Windows Phone, WinRT and WPF applications. It provides access to all aspects of any running XAML application. Interact with the UI visual tree, monitor events, extract XAML, explore the contents of the package and isolated storage, view statistics and more
Home:
http://xamlspy.com/
exmachina
raize Codesite
« Reply #28 on: October 21, 2013, 03:33:27 PM »
CodeSite Logging System gives developers deeper insight into how their code is executing, which enables them to locate problems more quickly and ensure their application is running correctly. CodeSite's logging classes let developers capture all kinds of information while their code executes and then send that information to a live display or to a log file. Furthermore, both styles of logging, live logging and file logging, can be performed locally or remotely (via TCP, UDP, or HTTP).
Home:
http://www.raize.com/DevTools/CodeSite/Default.asp
exmachina
Re: Atomineer
« Reply #29 on: October 21, 2013, 03:38:10 PM »
Looks good, but the installer does not work well , at least on my machine (non English OS), and I had to register the addin manually
