Author Topic: ---{Challenge}--- Compare two expressions  (Read 3546 times)
Jeremy
« on: July 29, 2015, 11:23:00 PM »
Alright gang, we are going to create a function that I will call SCOMPARE that is short for "Structure Compare". This function takes two arguments x and y that are any two valid expressions. The function must return T if both expressions have the same structure and nil otherwise, it is a higher order function. To clarify better here are some examples:
(scompare 3 (list a b)) -> nil
(scompare (list a b)(list c d)) -> T ;can have different atoms but nesting must be the same
(scompare (list a b)(c . d)) -> nil ;conses not the same as lists
(scompare (list a (list b c))(list d (list e f))) -> T
I hope I have defined the task adequately. Let the programs begin!
Re: ---{Challenge}--- Compare two expressions
« Reply #1 on: July 29, 2015, 11:53:16 PM »
Jeremy,
Can we assume you want to assert the TYPE of the content of lists ; not that they evaluate to the same thing.
added: Do you only care that the variable contains say a 2 element list.
I imagine you will want the differentiate between a 3 element list of reals and a 3 element list of lists ... ?
There will be some clarification of your rules required.
An edge case :
  1. (setq a 42
  2.       b 2.2
  3. )
  4.
  5. (setq v1 (list a b)
  6.       v2 '(a b)
  7. )
  8.
  9.
  10. (type v1)       ;-> LIST
  11. (type v2)       ;-> LIST
  12.
  13. (type a)        ;=> INT
  14. (type (car v1)) ;=> INT
  15.
  16. (type (car v2))  ;=> SYM
  17.
  18. (type (eval (car v1)) )  ;=> INT
  19.
  20. (type (eval (car v2)) )  ;=> INT
  21.
« Last Edit: July 29, 2015, 11:58:49 PM by Kerry »
bruno_vdh
« Reply #2 on: July 30, 2015, 03:19:50 AM »
Hello,
My proposal for a similar structure...
(defun bv:scompare (a b)
  (cond ((atom a) (atom b))
        ((atom b) nil)
        ((bv:scompare (car a) (car b)) (bv:scompare (cdr a) (cdr b)))
Regards,
roy_043
  • BricsCAD 18
« Reply #3 on: July 30, 2015, 03:31:54 AM »
Hello,
        ((atom b) nil)
Regards,
I think we may already have our winner... Very good bruno_vdh!
« Reply #4 on: July 30, 2015, 04:28:08 AM »
        ((atom b) nil)
Excellent work bruno - I doubt there is a more elegant solution than that!  :-)
Just for fun, here is another:
  1. (defun scompare ( a b )
  2.     (or (and (atom  a) (atom  b))
  3.         (and (listp a) (listp b) (= (length a) (length b)) (vl-every 'scompare a b))
  4.     )
  5. )
Incompatible with dotted pairs however, as a 'car/cdr' iterator must be used.
bruno_vdh
« Reply #5 on: July 30, 2015, 05:34:58 AM »
Thank you to both of you, your forum is very good
Yes, dotted pairs with difficult to work differently
My variant for this hypothθse
(defun bv:compareStrTyp (a b)
  (if (or (atom a) (atom b))
    (eq (type a) (type b))
    (and (bv:compareStrTyp (car a) (car b)) (bv:compareStrTyp (cdr a) (cdr b)))
Regards,
« Reply #6 on: July 30, 2015, 05:49:59 AM »
Rewriting mine for type comparison:
  1. (defun scomparetyp ( a b )
  2.     (if (and (listp a) (listp b))
  3.         (and (= (length a) (length b)) (vl-every 'scomparetyp a b))
  4.         (= (type a) (type b))
  5.     )
  6. )
Jeremy
« Reply #7 on: July 30, 2015, 03:39:14 PM »
When I originally conceived this problem I was thinking in terms of having a function that could MAPCAR lists of any nested structure rather than just vector lists. So for instance we could do something like (newmapcar '+ (list 1 (list 2 3))(list 4 (list 5 6))) -> (list 5 (list 7 9)). To do this however you need a function like SCOMPARE so that you can tell if your two input structures are compatible. So this is kind of where I was aiming for. With such a mapcar one could take any dyadic function and make it super general. In the case of addition one would not have to write extra addition operators for vector addition, matrix addition etc.
You guys are fast with the answers!
bruno_vdh
« Reply #8 on: July 30, 2015, 04:41:04 PM »
Quickly, on the same algorithm a simple version:
(defun maptree (f l m)
    ((null l) nil)
    ((atom l) (apply f (list l m)))
    ((cons (maptree f (car l) (car m)) (maptree f (cdr l) (cdr m))))
_$ (maptree '+ (list 1 (list 2 3))(list 4 (list 5 6)))
(5 (7 9))
Regards,
« Reply #9 on: July 30, 2015, 04:54:33 PM »
Another (since mapcar also cannot process dotted pairs):
  1. (defun maptree ( f l m )
  2.     (if (atom l) ((eval f) l m) (mapcar '(lambda ( a b ) (maptree f a b)) l m))
  3. )
  1. _$ (maptree '+ (list 1 (list 2 3))(list 4 (list 5 6)))
  2. (5 (7 9))
« Reply #10 on: July 30, 2015, 05:52:32 PM »
Or, since mapcar accepts multiple list arguments:
  1. (defun maptree ( f l )
  2.     (if (atom (car l))
  3.         (apply f l)
  4.         (mapcar '(lambda ( x ) (maptree f x)) (apply 'mapcar (cons 'list l)))
  5.     )
  6. )
  1. _$ (maptree '+ (list (list 1 (list 2 3)) (list 4 (list 5 6)) (list 7 (list 8 9))))
  2. (12 (15 18))
bruno_vdh
« Reply #11 on: July 30, 2015, 06:00:38 PM »
Nice Lee, especially the second,
In the first beware of ((eval f) l m), it does not support special form.
I prefer (apply f (list l m)) slower
Or (eval (list f  l m))  more general
Regard,
« Last Edit: July 30, 2015, 06:06:14 PM by bruno_vdh »
« Reply #12 on: July 30, 2015, 06:19:11 PM »
Thanks bruno  :-)
Good catch & suggestions -
  1. _$ (maptree 'and '(t (t nil)) '(t (t t)))
  2. ; error: cannot apply special form: AND
Fixed -
  2.     (if (atom l)
  3.         (apply f (list l m))
  4.         (mapcar '(lambda ( a b ) (maptree f a b)) l m)
  5.     )
  6. )
  2. (T (T nil))
bruno_vdh
« Reply #13 on: July 31, 2015, 06:38:27 AM »
For the game, and not have to rewrite the function  :wink:
http://www.theswamp.org/index.php?topic=49813.msg550282#msg550282
_$ (reduceKey 'maptree '+ '((1 (2 3)) (4 (5 6)) (7 (8 9))))
(12 (15 18))
Regards,
