Author Topic: CAB,something wrong with "get_group_boundingbox.lsp",please help.  (Read 6487 times)
cjw
;;;       +            get_group_boundingbox.lsp                   +
;;;       +            Created by C. Alan Butler                   +
;;;       +               Copyright 2005                           +
;;;       +   by Precision Drafting & Design All Rights Reserved.  +
;;;       +    Contact at ab2draft@TampaBay.rr.com                 +
;;; Get a bounding box for a group of bounding boxes
;;; Use the base of the first box as a referance angle that will be
;;; the base angle of the box returned
;;;   argument 'all; is a list of 4 point lists defining the group of boxes
 (defun get_group_boundingbox (all / ld lb rd rb bd bb td tb tmp refpt angr
                               ang angr s1 s2 pt  anglst intersect dist)
  ;; return intersect point between two borders
  (defun intersect (s1 s2 ang / angr)
    (if (>= ang (* pi 1.5)) ; ANGLE PLUS 90 DEG
      (setq angr (- ang (* pi 1.5))) ; -270 deg
      (setq angr (+ ang (/ pi 2))) ; +90 deg
    (inters s1 (polar s1 angr 10) s2 (polar s2 ang 10) nil)
  ) ; end defun
  ;; calc distance & perpenduclar point on border
  (defun dist (p1 ang p3 p4 / p2 p5 d angp1p5)
    (setq p2 (polar p1 ang 10) ; point on line at angle
          p5 (inters p1 p2 p3 p4 nil) ; perpendicular point
          d  (distance p1 p5)
    ;;  this is needed when angp1p5 is = 2pi
    (if (equal (angle p1 p5) (* 2 pi) 0.00001)
      (setq angp1p5 0.0)
      (setq angp1p5 (angle p1 p5))
    (if (equal angp1p5 ang 0.00001)
      (list (distance p1 p5) p5)
      (list (- (distance p1 p5)) p5)
    ;;  returns (dist point)
  ) ; end defun
   ;;   start of get_group_boundingbox
  (setq ld    0 ; ld Left Distance : lb Left Broder pt
        rd    0
        td    0
        bd    0
        ;; constant referance point for calcs, it is within the first box
        refpt (polar (caar all) (angle (caar all) (caddar all))
                     (/ (distance (caar all) (caddar all)) 2))
        ang   (angle (caar all) (cadar all)) ; constant angle for calcs
        angr  (if (>= ang (* pi 1.5)) ; ANGLE PLUS 90 DEG
                (- ang (* pi 1.5)) ; -270 deg
                (+ ang (/ pi 2)) ; +90 deg
  ;;  this is needed when ang is = 2pi
  (if (equal ang (* 2 pi) 0.00001)
    (setq ang 0.0)
  ;;  find point on outer most border
  (foreach pt all
    ;; Right Border (ll lr ur ul) -> lr ur -> (cadr pt) (caddr pt)
    (if (>= (car (setq tmp (dist refpt ang (cadr pt) (caddr pt)))) rd)
      (setq rb (cadr tmp) ; new border point
            rd (car tmp) ; new distance
    ;; Left Border (ll lr ur ul) -> ll ul -> (car pt) (cadddr pt)
    (if (<= (car (setq tmp (dist refpt ang (car pt) (cadddr pt)))) ld)
      (setq lb (cadr tmp) ; new border point
            ld (car tmp) ; new distance
    ;; Top Border (ll lr ur ul) -> ur ul -> (cadr pt) (caddr pt)
    (if (>= (car (setq tmp (dist refpt angr (caddr pt) (cadddr pt)))) td)
      (setq tb (cadr tmp) ; new border point
            td (car tmp) ; new distance
    ;; Bottom Border (ll lr ur ul) -> ll lr -> (car pt) (cadddr pt)
    (if (<= (car (setq tmp (dist refpt angr (car pt) (cadr pt)))) bd)
      (setq bb (cadr tmp) ; new border point
            bd (car tmp) ; new distance
  ) ; foreach
  ;;      get intersect point between two borders
  ;;  Left Border & Bottom Border = Lower left pt
  (list (intersect lb bb ang) ; ll
        (intersect rb bb ang) ; lr
        (intersect rb tb ang) ; ur
        (intersect lb tb ang) ; ul
   ;;  returns (ll lr ur ul)
) ; end defun get_group_boundingbox
;;;       +                   box_text                             +
;;; VERSION
;;;  1.2 Jan 24, 2006  UCS corrections
;;;  1.3 Nov 26, 2008  Fixed Bug when text was rotated
;;; FUNCTION
;;;  Return Box coordinates for an dtext object in any UCS, any angle.
;;; USAGE
;;;  (box_text ent)
;;; ARGUMENTS
;;;  ent = text ename
;;;  RETURNS
;;;   list of 4 points for box,  (ll lr ur ul)
;;; PLATFORMS
;;;  2000+ Tested in 2000 only
;;; FUNCTION
(defun box_dtext (ent / i ename elist lst lst2 tb tb1 tb2 tlen thi ll lr
                  ur ul ang angg UCSang llx lrx urx ulx lly lry ury uly all
                   avg err cntlst
  (setq UCSang (angle (trans '(0.0 0.0 0.0) 1 0)
                      (trans '(1.0 0.0 0.0) 1 0)
  ;;      get the bounding box
    (setq elist (entget ent)
          ang   (cdr (assoc 50 elist)) ; text angle
          tb    (textbox elist) ; Note that I had some problems with this
          ;tb    (textbox (list (assoc 1 elist) (assoc 40 elist)(assoc 7 elist)));(textbox (list (assoc 1 elist))) ; CAB 11.11.08
          tb1   (car tb)  ; Lower Left Relative to text
          tb2   (cadr tb) ; Upper Right relative to text
          tlen  (- (car tb2) (car tb1))
          thi   (- (cadr tb2) (cadr tb1))
(setq     ang   (- ang UCSang) ; correct for UCS
          ll  (polar (trans (cdr (assoc 10 elist)) 0 1)
                     (+(angle '(0 0) tb1) ang) (DISTANCE '(0 0) tb1)) ; CAB 11.26.2008
          lr    (polar ll ang tlen)
          ur    (polar ll (+ ang (angle tb1 tb2)) (distance tb1 tb2))
          ul    (polar ll (+ ang (/ pi 2)) thi)
    ) ;setq
    (list ll lr ur ul)
) ; end defun box_dtext
;;; x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x
Test the drawing with the code.
(defun C:TT ()
  (setq BOX_PTS '())
  (setq SS (ssget '((0 . "TEXT"))))
  (repeat (setq I (sslength SS))
    (and (setq E (ssname SS (setq I (1- I))))
(setq BOX (BOX_DTEXT E))
(setq BOX_PTS (cons BOX BOX_PTS))
  (setq 4PTS (GET_GROUP_BOUNDINGBOX BOX_PTS))
Re: CAB,something wrong with "get_group_boundingbox.lsp",please help.
« Reply #1 on: October 12, 2010, 01:24:42 PM »
I'll have some time to look this over this afternoon.
cjw
« Reply #2 on: October 13, 2010, 01:04:15 AM »
Thank you for taking the time to answer.
Joe Burke
« Reply #3 on: October 13, 2010, 09:48:38 AM »
This may be of interest.
;; Argument: a selection set.
;; Returns the bounding box of selection set
;; in WCS coordinates. A two point list,
;; lower left and upper right.
(defun SSBndBox (ss / idx obj lst ptlst)
  (setq idx 0)
  (repeat (sslength ss)
    (setq obj (vlax-ename->vla-object (ssname ss idx))
          lst (cons obj lst)
          idx (1+ idx)
  (foreach x lst
    (vla-getboundingbox x 'mn 'mx)
    (setq ptlst (cons (vlax-safearray->list mn) ptlst))
    (setq ptlst (cons (vlax-safearray->list mx) ptlst))
  ;following by Tony Tanzillo
  (list
    (apply 'mapcar (cons 'min ptlst))
    (apply 'mapcar (cons 'max ptlst))
) ;end
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: October 13, 2010, 10:30:22 AM »
acet function:
(setq ss  (ssget)
      lst_p '((0 0 0) (1 1 1) (0 1 0))
      e   (car lst)
) ;_  setq
(ACET-ENT-GEOMEXTENTS e)
(ACET-GEOM-EXTENTS e)
(ACET-GEOM-LIST-EXTENTS lst_p)
(ACET-GEOM-SS-EXTENTS ss 1e-3)
(ACET-GEOM-SS-EXTENTS-ACCURATE ss)
(ACET-GEOM-SS-EXTENTS-FAST ss)
(ACET-SS-REMOVE-DUPS-EXTENTS-LIST ss 1e-3)
(ACET-SS-ZOOM-EXTENTS ss)
(ACET-GEOM-SS-EXTENTS ss t)
(ACET-GEOM-MTXTBOX (entget(car(entsel "\nMtext"))) 1e-3)
« Reply #5 on: October 13, 2010, 10:49:34 AM »
I wouldn't rely on the ACET functions  :|
This is what I use...
(defun SSBoundingBox ( ss / ent ll ur bBoxs )
  ;; © Lee Mac 2010
  (  (lambda ( i )
       (while (setq ent (ssname ss (setq i (1+ i))))
         (vla-getBoundingBox (vlax-ename->vla-object ent) 'll 'ur)
         (setq bBoxs (cons (vlax-safearray->list ur)
                           (cons (vlax-safearray->list ll) bBoxs)))
    -1
  (mapcar
    (function
      (lambda ( operation )
        (apply (function mapcar) (cons operation bBoxs))
    '(min max)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: October 13, 2010, 11:56:31 AM »
I think the same way :)
as an example:
Creat VECTOR_IMAGE
(defun lst-getboundingbox (lst / maxp minp)
  (if (and lst (listp lst))
    (apply
      (function
        (lambda (a1 a2 a3 a4 a5 a6)
          (list
            (list
              (apply (function min) a1)
              (apply (function min) a2)
              (apply (function min) a3)
            ) ;_  list
            (list
              (apply (function max) a4)
              (apply (function max) a5)
              (apply (function max) a6)
            ) ;_  list
          ) ;_  list
        ) ;_  lambda
      ) ;_  function
      (apply
        (function mapcar)
        (cons
          'list
          (mapcar
            (function
              (lambda (x)
                (vla-getboundingbox x 'minp 'maxp)
                (append
                  (vlax-safearray->list minp)
                  (vlax-safearray->list maxp)
                ) ;_  list
              ) ;_  lambda
            ) ;_  function
            lst
          ) ;_  mapcar
        ) ;_  cons
      ) ;_  apply
    ) ;_  apply
  ) ;_  if
) ;_  defun
« Reply #7 on: October 13, 2010, 12:10:27 PM »
Lot's of good suggestions.
While I check then out here is my revised routine.
Ops, in my clean up I deleted too many ). Revised post.
;;;   -=<  Revised 10/13/2010  >=-
;;;     Bug Fix - when one text box is not aligned with the others
  ) ; end defun
(defun dist (p1                         ;  constant referance point
             ang                        ; Angle Allowed +/-
             4pts
             p3 p4 p5 lst
             dst  ; used to prevent conditions when the box is off angle and
             ;;   inters returns a crossing point at a great distance
  (setq 4pts (append box (list (car 4pts)))
        dst  (apply (function max) (mapcar(function(lambda(x) (distance p1 x))) 4pts))
  (while (cadr 4pts) ; check all sides
    (setq p3 (car 4pts)
          p4 (cadr 4pts)
    (setq 4pts (cdr 4pts)
    (if (and p5 (equal ang (NormAng (angle p1 p5)) 0.0001))
        (if (and (< (distance p1 p5) dst)
                 (or (null lst)
                     (> (distance p1 p5)(distance p1 (caddr lst))))
          (setq lst (list p3 p4 p5))
  (if lst
    (list (abs (distance p1 (last lst))) (list (car lst) (cadr lst))) ;  returns
)                                       ; end defun
   ;; correct for > 2pi
   (defun NormAng (a)
     (if (>= a (- (* 2 pi) 0.00001))
       (- a (* 2 pi))
       a
   (defun AddAngles (a1 a2 / tmp)
     (if (>= (setq tmp (+ a1 a2)) (- (* 2 pi) 0.00001))
       (- tmp (* 2 pi))
       tmp
        rd    0
        td    0
        bd    0
        ;;  note that this may be anywhere within the group of boxes
    (setq ang 0.0)
  ;;  Check each text box and find find point on outer most border
  (foreach box all
    ;; Right Border (ll lr ur ul) -> lr ur -> (cadr box) (caddr box)
    (if (and (setq tmp (dist refpt ang box))
             (or (>= (car tmp) rd) (null rb)))
      (setq rb (cadr tmp) ; new border points
    ;; Left Border (ll lr ur ul) -> ll ul -> (car box) (cadddr box)
    (if (and (setq tmp (dist refpt (AddAngles ang pi) box))
             (or (>= (car tmp) ld) (null lb)))
      (setq lb (cadr tmp) ; new border points
    ;; Top Border (ll lr ur ul) -> ur ul -> (cadr box) (caddr box)
    (if (and (setq tmp (dist refpt (AddAngles ang (* 0.5 pi)) box))
             (or(>= (car tmp) td) (null tb)))
      (setq tb (cadr tmp) ; new border points
    ;; Bottom Border (ll lr ur ul) -> ll lr -> (car box) (cadddr box)
    (if (and (setq tmp (dist refpt (AddAngles ang (* 1.5 pi)) box))
             (or(>= (car tmp) bd) (null bb)))
      (setq bb (cadr tmp) ; new border points
  ) ; foreach
   (list
     (inters (car lb)(cadr lb)(car bb)(cadr bb) nil)
     (inters (car rb)(cadr rb)(car bb)(cadr bb) nil)
     (inters (car rb)(cadr rb)(car tb)(cadr tb) nil)
     (inters (car lb)(cadr lb)(car tb)(cadr tb) nil)
« Last Edit: October 13, 2010, 12:20:44 PM by CAB »
« Reply #8 on: October 13, 2010, 12:23:25 PM »
FYI, this is the desired result using plain text. 8-)
Joe Burke
« Reply #9 on: October 14, 2010, 07:45:24 AM »
Maybe I'm missing something?
I thought the desired result is the minimum bounding box (lower left and upper right points) which encloses the bounding boxes of all the seleted objects.
« Reply #10 on: October 14, 2010, 08:18:37 AM »
Yes, the bounding box of the smaller boxes BUT not WCS but rotated to match the rotation of the first bounding box supplied in the list of smaller bounding boxes.
If I am being clear?
The box_dtext.lsp returns a bounding box of plain text which matches it's angle.
So you feed it the ename of the text one by one to get your list of 4 point list.
Then you feet that list to get_group_boundingbox.lsp which returns the box for the group of boxes. All
based on the angle of the first 4 point list in the master list.
« Reply #11 on: October 14, 2010, 08:23:15 AM »
See this rotated view.
Give this lisp a try. http://www.theswamp.org/index.php?topic=7003.0
<edit: file deleted and link added as you need the zip file to get all you need.>
« Last Edit: October 14, 2010, 09:29:02 AM by CAB »
cjw
« Reply #12 on: October 14, 2010, 08:51:35 AM »
So hard.
Thank you verrrry much.
CAB,you are great.
cjw
« Reply #13 on: October 14, 2010, 08:56:26 AM »
And thank you all.
You are all nice guys.
Joe Burke
« Reply #14 on: October 14, 2010, 10:05:17 AM »
I get it now. Thanks for clarification.
