Author Topic: vlax-get-property  (Read 2494 times)
Ron Heigh
vlax-get-property
« on: September 09, 2004, 04:42:00 PM »
Is there somewhere I could find a list of properties to use with the vlax-get-property function?
I need to get the dxf 41 code and want to try to set it to an absolute value using VLisp.
SMadsen
vlax-get-property
« Reply #1 on: September 09, 2004, 04:51:55 PM »
Not sure what you mean with dxf code 41 but object properties are listed and described in the VBA Reference in online help.
vlax-get-property
« Reply #2 on: September 09, 2004, 04:58:48 PM »
this is what i find on code 41 and TEXT
41   Relative X scale factor—width (optional; default = 1)
This value is also adjusted when fit-type text is used.
vlax-get-property
« Reply #3 on: September 09, 2004, 05:21:32 PM »
Ron Heigh
vlax-get-property
« Reply #4 on: September 09, 2004, 06:56:14 PM »
Thanks everyone.
I found the reference in the help file.
It is XScaleFactor.
