Author Topic: Filter for drawing files  (Read 2002 times)
GDF
« on: March 26, 2009, 02:41:18 PM »
At a loss...
(setq DwgList (vl-directory-files DirPath "A*.dwg" 1))
How would I modify the above line to filter all A, M, E, P and S letters?
Gary
Re: Filter for drawing files
« Reply #1 on: March 26, 2009, 02:46:14 PM »
(setq DwgList (vl-directory-files DirPath "[AMEPS]*.dwg" 1))
« Reply #2 on: March 26, 2009, 02:56:08 PM »
At a loss...
Gary
I don't believe vl-directory-files supports wcmatch filtering, but supports traditional DOS dir command wild carding (?|*).
If true, then:
(vl-remove-if-not
   '(lambda (x) (wcmatch (strcase x) "[AMEPS]*"))
    (vl-directory-files DirPath "*.dwg" 1)
Should work.
<untested|coded blind>
Edit: Fixed dumb typo, wth is with me lately.
« Last Edit: March 26, 2009, 03:00:34 PM by MP »
GDF
« Reply #3 on: March 26, 2009, 03:03:50 PM »
Michael and Alan
Michael your solution worked pecfectly.
Thanks again guys
« Reply #4 on: March 26, 2009, 03:06:16 PM »
Michael and Alan
Thanks again guys
That there is poetry.  :-D
<glad it worked>
