Author Topic: Custom DwgProps in vba?  (Read 3290 times)
Matersammichman
« on: January 29, 2007, 11:07:02 AM »
Is there a way to create Custom Property Names in vba similar to that defined using the
"-dwgprops" command, "Custom" tab?
I want to create/define my own custom fields with vba (not lisp, vlsp, arx...). :-P
David Hall
  • Automatic Duh Generator
Re: Custom DwgProps in vba?
« Reply #1 on: January 29, 2007, 11:08:36 AM »
I think youcan modify that tab using vba, let me look to see if I have code for that
Matersammichman
« Reply #2 on: January 29, 2007, 11:37:33 AM »
I've got it now Cmdr. Thanks for the help!
David Hall
« Reply #3 on: January 29, 2007, 11:49:03 AM »
cool, I just found it, but see you got it already
Matersammichman
« Reply #4 on: January 29, 2007, 11:52:09 AM »
What I got was an example from Autocad, but I can easily modify it to work.
Here it is...
    Sub Example_SummaryInfo()
   ' This example shows how to access drawing properties
   ' Add and display standard properties
   ThisDrawing.SummaryInfo.Author = "John Doe"
   ThisDrawing.SummaryInfo.Comments = "Includes all ten levels of Building Five"
   ThisDrawing.SummaryInfo.HyperlinkBase = "http://www.autodesk.com"
   ThisDrawing.SummaryInfo.Keywords = "Building Complex"
   ThisDrawing.SummaryInfo.LastSavedBy = "JD"
   ThisDrawing.SummaryInfo.RevisionNumber = "4"
   ThisDrawing.SummaryInfo.Subject = "Plan for Building Five"
   ThisDrawing.SummaryInfo.Title = "Building Five"
   Author = ThisDrawing.SummaryInfo.Author
   Comments = ThisDrawing.SummaryInfo.Comments
   HLB = ThisDrawing.SummaryInfo.HyperlinkBase
   KW = ThisDrawing.SummaryInfo.Keywords
   LSB = ThisDrawing.SummaryInfo.LastSavedBy
   RN = ThisDrawing.SummaryInfo.RevisionNumber
   Subject = ThisDrawing.SummaryInfo.Subject
   Title = ThisDrawing.SummaryInfo.Title
   MsgBox "The standard drawing properties are " & vbCrLf & _
          "Author = " & Author & vbCrLf & _
          "Comments = " & Comments & vbCrLf & _
          "HyperlinkBase = " & HLB & vbCrLf & _
          "Keywords = " & KW & vbCrLf & _
          "LastSavedBy = " & LSB & vbCrLf & _
          "RevisionNumber = " & RN & vbCrLf & _
          "Subject = " & Subject & vbCrLf & _
          "Title = " & Title & vbCrLf
   ' Add and display custom properties
   Dim Key0 As String
   Dim Value0 As String
   Dim Key1 As String
   Dim Value1 As String
   Dim CustomPropertyBranch As String
   Dim PropertyBranchValue As String
   Dim CustomPropertyZone As String
   Dim PropertyZoneValue As String
   CustomPropertyBranch = "Branch"
   PropertyBranchValue = "Main"
   CustomPropertyZone = "Zone"
   PropertyZoneValue = "Industrial"
   ' Add custom properties
   If (ThisDrawing.SummaryInfo.NumCustomInfo >= 1) Then
      ThisDrawing.SummaryInfo.SetCustomByIndex 0, CustomPropertyBranch, PropertyBranchValue
   Else
      ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyBranch, PropertyBranchValue
   End If
   If (ThisDrawing.SummaryInfo.NumCustomInfo >= 2) Then
       ThisDrawing.SummaryInfo.SetCustomByKey CustomPropertyBranch, "Satellite"
   Else
       ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyZone, PropertyZoneValue
   End If
   'Get custom properties
   ThisDrawing.SummaryInfo.GetCustomByIndex 0, Key0, Value0
   Key1 = CustomPropertyZone
   ThisDrawing.SummaryInfo.GetCustomByKey Key1, Value1
   MsgBox "The custom drawing properties are " & vbCrLf & _
          "First property name = " & Key0 & vbCrLf & _
          "First property value = " & Value0 & vbCrLf & _
          "Second property name = " & Key1 & vbCrLf & _
          "Second property value = " & Value1 & vbCrLf
