Author Topic: IP address...  (Read 13875 times)
IP address...
« Reply #15 on: March 05, 2005, 08:56:17 PM »
You mean like this?
I was able to get the ipaddress using wmi but when I tried to write it out to a temp file using the File System Object ... tada. I'm still working on it (i.e. I refuse to be beat by a dumb ol' puter).
Are you trying something similar?
:D
IP address...
« Reply #16 on: March 05, 2005, 09:06:29 PM »
Over at the autodesk.autocad.customization newsgroup, Thomas Smith posted a small routine that accesses the registry and reports the IP address. It is in a thread entitled, oddly enough, "IP Address" that was started on December 10, 2003. I just tested it on my WinXP Home laptop and it returned the proper value. You might want to look at it. He did post a few attempts, make sure to grab the last one.
I didn't repost it here, as I'm unsure of the legality and/or ethics of doing such a thing.
IP address...
« Reply #17 on: March 05, 2005, 09:16:25 PM »
What, and take all the fun out of it?
Genuine thanks Jeff, but I'm having fun researching this -- copying existing code would be snoozeville. There's buckets of free info at MSDN. Just enough to make the task interesting but not wheel inventing.
:D
'Course, my MSDN membership dues weren't cheap.
IP address...
« Reply #18 on: March 05, 2005, 09:24:24 PM »
Quote from: MP
You mean like this?
:D
Yep.
I have used the FSO a lot, mainly 'cause of the speed.
I've been able to control my local scanner enviromment no problems, but a couple of my clients have had a bit more trouble ... some scanners don't provide the same selectable options regarding "ignoring" certain applications.
I need to do a bit of study on this when the swirling waters subside a little.
added:
interesting vbs name !!
hehehe
IP address...
« Reply #19 on: March 05, 2005, 09:37:20 PM »
Quote from: MP
Not my intent at all, Michael. In fact I plan on playing around with it some myself. My post was supposed to have been directed towards Andrea since it seemed like they wanted  something to work with now, it's just that Kerry and you manged to post while I was composing mine.... :?
So, carry on with your pursuit of knowledge...  :twisted:
edited in response to others' notification of Andrea's gender, which is the way I was going to post originally...my apologies to Andrea...
IP address...
« Reply #20 on: March 05, 2005, 10:43:01 PM »
Quote from: Jeff_M
Not my intent at all, Michael. In fact I plan on playing around with it some myself. My post was supposed to have been directed towards Andrea since it seemed like she wanted  something to work with now, it's just that Kerry and you manged to post while I was composing mine.... :?
I may be mistaken, but I thought Andrea was a >he<. :oops:
Quote from: Jeff_M
Indeed! You too Jeff. :lol:
Quote from: Kerry
interesting vbs name !! hehehe
Create Retrieve Update Destroy.
Moo ha ha ha. :twisted:
daron
IP address...
« Reply #21 on: March 05, 2005, 11:35:18 PM »
Ahem!!! Jeff??? Andrea is a he, not a she.
Carry-on!
IP address...
« Reply #22 on: March 06, 2005, 11:41:46 AM »
After trying a number of avenues it suddenly dawned on me ...
... if you add this line to your acad.pgp file:
HiddenShell,,4,*OS Command:,
This code will not flash the DOS window:
<See next post>
:D
Well off to church, catch ya later.
Edit: Removed code; superfluous given next post.
IP address...
« Reply #23 on: March 06, 2005, 08:20:40 PM »
Here ya go.
Written quickly. This means there are errors I failed to find | fix. Please follow prudent backup / testing methodologies. No warranty for any particular use is stated or implied. Use at your own risk.
(defun FindItemInFile ( PredicateFunction filename / handle item )
    ;;  © 2005 Michael Puckett
            (eq 'str (type filename))
            (setq handle (open filename "r"))
        (vl-catch-all-apply
           '(lambda ( / stream )
                (while (setq stream (read-line handle))
                        (   (PredicateFunction stream)
                            (close handle)
                            (setq item stream)
                            (exit)
                (close handle)
    item
(defun HiddenShellInPgpFile ( / filepath filebackup handle )
    (or
        (FindItemInFile
            (lambda (stream)
                (wcmatch
                    (strcase (vl-string-trim " \t\n" stream))
                    "HIDDENSHELL`,`,4`,`*OS COMMAND:`,"
            (setq filepath (findfile "acad.pgp"))
            filepath
            (setq filebackup (vl-filename-mktemp filepath))
            (vl-file-copy filepath filebackup)
            (setq handle (open filepath "a"))
            (princ "\nHiddenShell,,4,*OS Command:,\n" handle)
            (null (close handle))
            (setvar "re-init" 16)
(defun HiddenShell ( statement / cmdecho )
            (HiddenShellInPgpFile)
            (setq cmdecho (getvar "cmdecho"))
            (setvar "cmdecho" 0)
            (command "HiddenShell" statement)
            (setvar "cmdecho" cmdecho)
            t
(defun GetIPAddress ( / tempfile ipAddressStream ipAddress )
            (HiddenShell
                (strcat "ipconfig.exe > "
                    (setq tempfile
                        (vl-filename-mktemp "ipconfig.txt")
            (setq ipAddressStream
                (FindItemInFile
                    (lambda (stream)
                        (wcmatch
                            (strcase stream)
                            "*IP ADDRESS*"
                    tempfile
        (setq ipAddress
            (vl-string-trim " "
                (vl-list->string
                    (cdr
                        (member 58
                            (vl-string->list ipAddressStream)
    (if tempfile (vl-file-delete tempfile)) ;; clean up our mess
    ipAddress
Cheers.
:D
Re: IP address...
« Reply #24 on: October 25, 2006, 03:24:31 PM »
Thanks for this function MP. I can use this :)
Re: IP address...
« Reply #25 on: October 25, 2006, 04:02:03 PM »
<blink> Thank you for taking the time to say so Ron!
Andrea
Re: IP address...
« Reply #26 on: October 26, 2006, 10:15:06 AM »
Carry-on!
thanks Daron. :lmao:
Keep smile...
Re: IP address...
« Reply #27 on: October 26, 2006, 03:24:51 PM »
Here's one
(defun ipaddress (/ item meth1 meth2 ml s wmi)
  (setq ml '()
WMI (vlax-create-object "WbemScripting.SWbemLocator")
meth1 (VLAX-INVOKE WMI 'ConnectServer nil nil nil nil nil nil nil nil)
meth2 (vlax-invoke meth1 'ExecQuery (strcat "Select IPAddress from Win32_NetworkAdapterConfiguration"))
S (vlax-for item meth2 (setq ml (append
  (vlax-get item 'IPAddress)
  ml
  (vlax-release-object meth1)
  (vlax-release-object meth2)
  (vlax-release-object wmi)
  s
and
(defun ping (address / result)
  (setq result (Win32_PingStatus address))
  (if (= (cadr result) 0)
    t
    nil
(defun Win32_PingStatus (Address / item meth1 meth2 s wmi x)
  (setq WMI (vlax-create-object "WbemScripting.SWbemLocator")
meth2 (vlax-invoke meth1 'ExecQuery (strcat "Select * From Win32_PingStatus where Address = '" address "'"))
S (vlax-for item meth2 (setq x (list (vlax-get item 'Address) (vlax-get item 'StatusCode) (vlax-get item 'ResponseTime))))
  s
Re: IP address...
« Reply #28 on: October 26, 2006, 03:31:53 PM »
Now I am a Newt!  :lmao:
Andrea
Re: IP address...
« Reply #29 on: October 26, 2006, 04:12:11 PM »
nice Daniel... :roll:
this was my old one..
(command "SH" "IPCONFIG > c:\\IPCFG.txt")
(setq f1 (open "c:\\IPCFG.txt" "r"))
(setq l1 (read-line f1))
(while l1
  (setq IPyes (vl-string-search "IP." l1))
  (if IPyes
    (setq sp (vl-string-position (ascii ":") l1))
    (setq IPA (substr l1 (+ sp 3)))
(close f1)
(alert (strcat "IP Adress is : " IPA))
(defun c:ping (/ pname f1 l1 IPyes)
(setq pname (getstring "Address : "))
(if pname
  (setq bfile (open "c:\\PIGNNAME.bat" "w"))
  (write-line (strcat "PING " pname " > c:\\PIGNNAME.txt") bfile)
 (close bfile)
(command pcommand)
(startapp "c:\\PIGNNAME.bat")
Keep smile...
