Author Topic: Plotting from PDFs  (Read 1522 times)
jonesy
  • SuperMod
Plotting from PDFs
« on: March 09, 2006, 08:13:57 AM »
We have an ancient xerox 8830 plotter. Recently we have started sending PDFs to be printed from it. It doesnt plot the whole of the drawing frame out. - It misses about 6inches off the edge.
Has anyone else had this problem and how did you rectify it.
Many thanks
Tracey :-)
Changed title sorry!
« Last Edit: March 09, 2006, 08:20:57 AM by jonesy »
David Hall
  • Automatic Duh Generator
Re: Plotting to PDF
« Reply #1 on: March 09, 2006, 08:16:26 AM »
what driver are you using?
Craig
Re: Plotting to PDF
« Reply #2 on: March 09, 2006, 08:18:25 AM »
Tracey, one thing you can try is to setup your printer as the Windows default system printer, then try replotting the PDF.
jonesy
  • SuperMod
Re: Plotting to PDF
« Reply #3 on: March 09, 2006, 08:19:18 AM »
This varies from machine to machine as there are different os and cad systems on the machines... would that make a difference? Could you have the same driver on all machines.
Bryco
Re: Plotting from PDFs
« Reply #4 on: March 09, 2006, 09:30:23 AM »
If you have all the drivers on the network computer it doesn't matter what os or cad system but it does matter what version of adobe
pmvliet
« Reply #5 on: March 09, 2006, 09:42:06 AM »
Depending if there are images or any type of graphic in the PDF's, you will want to make sure that the driver you are using for the 8830 is a posctscript driver.
(at my old place of employment) We had a pair of 8830's for the 8 years I was there and just last month they were replaced with a pair of Oce's
Pieter
