CAD Forums => CAD General => Topic started by: M-dub on November 11, 2008, 09:09:42 AM
Wasn't sure if this should have gone in the Pixel This forum but since it's CAD related, here it is...
I have a grayscale image that I would like to convert to bitonal. To do this, I select Image > Image Processing > Change Color Depth and choose Bitonal. The result is quite useless, as seen in the attached images.
There must be a way to improve this. Does anyone have any suggestions? Maybe using a different application? They aren't going to buy anything else, though.
Thanks!
Do a search for Imagemagick and then look at the convert command.
This is a set of stamped originals that we're scanning for our records. I wasn't able to get exactly what I wanted from our large format scanner, so I ended up scanning two copies of each at different quality settings. One setting results in a 75MB TIF and the other gives me a 3 - 5MB GP4. I'm just going to be storing the TIF's on a DVD anyway.
I'm going to have our scanner maintenance guy have a look and see what he can do next time he's here.
Thanks for the suggestion, Swift.
Another solution might be to download the trial version of Raster design to convert your images :-)
Why? Does the trial version do something that the full blown version doesn't? ;)
