Author Topic: Macro Commands  (Read 22019 times)
Macro Commands
« Reply #105 on: July 01, 2004, 04:21:37 PM »
Are you using LT?, you might try this ...
osmode 64;copy;\\@
You can also use select to pick an object and lastpoint to retrieve the point but there is no good way of moving that to the command that I know of.
osmode 64;select;\\$(getvar, lastpoint)
hyposmurf
Macro Commands
« Reply #106 on: March 14, 2005, 06:20:48 PM »
Use this to set my text/dim layer current when I use my custom MTEXT button.
^C^C-LAYER;S;SML_TEXT;;MTEXT
Use this to set my text/dim layer current when I use my custom QLEADER button.
^C^C-LAYER;S;SML_TEXT;;QLEADER
hudster
Macro Commands
« Reply #107 on: April 22, 2005, 04:01:33 PM »
found this one to toggle between model space and paper space using a button
(setvar "tilemode" (- 1 (getvar "tilemode")))
I though it was kinda neat
nivuahc
Macro Commands
« Reply #108 on: April 22, 2005, 04:10:50 PM »
My two favorites:
(startapp "C:/windows/explorer.exe" (getvar "DWGPREFIX"))
Opens Explorer in the directory of the drawing you're working on
(startapp "C:/Program Files/Mozilla Firefox/firefox.exe" "http://www.theswamp.org/")
This one, I think, doesn't need any explanation.  8)
