Hello all.
There is something I am just not gettin with regards to using grips to edit a cylinder. Lets say, I, from the righ side, draw a cylinder of some diameter and some height. I then change the view to top. What you have, in appearance is a rectangle. If you highlight it, and you then see the grips that are associated with a cylinder. If I grab the stretch one, and pull it left or right, you see a line go up and down and it will not stretch the cylinder. Now, if I change the view to isometric, I can stretch the cylinder. Why am I not able to stretch it in the top view?
Thanks!
