Author Topic: Question 10  (Read 1642 times)
Craig
Question 10
« on: August 16, 2005, 06:57:46 AM »
The XCLIP command is used to crop external referenced files and blocks and display a specified region.
Craig
Question 10
« Reply #1 on: August 16, 2005, 07:00:24 AM »
Meant to add
There are several ways to define the boundary, with varying results. If a polyline containing arcs is used, the clipping boundary is drawn straight, as though there were no curves when it was created. Similarly, if a curve-fit polyline is used, the clipping boundary is drawn as a straight-edged outline, ignoring the curves. However, if a polyline set as a spline is selected as the clipping boundary, it is left curved. Multiple blocks and/or external reference files can be included in a single clip boundary.
Question 10
« Reply #2 on: August 16, 2005, 07:07:05 AM »
Good points to tack onto this.
