Author Topic: Primavera SDK Doesn't Work with 64-bit Vista  (Read 2419 times)
Swift
« on: April 23, 2010, 02:57:50 PM »
No question here just some random information someone may find useful later.
After wasting the afternoon away, I have found the ODBC driver for Primavera doesn't work properly with 64-bit Windows. I have also found several posts around the web with the same conclusions but found nothing public from Oracle. So I made my own under UserDSN for SQLServer and pointed it at the proper database.
So using SQL Server Management Studio to navigate the tables and fields I can query the data
using System;
using System.Data.Odbc;
namespace ODBC_1
class Program
public static void Main(string[] args)
OdbcConnection DbConn = new OdbcConnection("DSN=PrimTest");
DbConn.Open();
OdbcCommand DbCom = DbConn.CreateCommand();
DbCom.CommandText ="SELECT rsrc_id FROM dbo.RSRC WHERE rsrc_name = 'Mobilization'";
OdbcDataReader DbReader = DbCom.ExecuteReader();
int iReturn = DbReader.FieldCount;
for ( int i = 0; i < iReturn; i ++ )
        String fieldName = DbReader.GetName(i);
        Console.Write( fieldName );
Console.WriteLine();
while( DbReader.Read())
            for (int i = 0; i < iReturn; i++)
                  String col = DbReader.GetString(i);
                        Console.Write(col);
DbReader.Close();
DbCom.Dispose();
DbConn.Close();
Console.Write("Press any key to continue . . . ");
Console.ReadKey(true);
Now I just have to work up the nerve to start manipulating data...
