Author Topic: Lisp Function instead of the one in Doslib  (Read 2137 times)
Tharwat
  • Hypersensitive
« on: July 03, 2011, 07:18:41 AM »
Hello .
I wonder if there is any Lisp function that does the same like the one in DOSlib .
(dos_show 0)
(dos_show 1)
(dos_show 2)
Thanks.
Tharwat
Re: Lisp Function instead of the one in Doslib
« Reply #1 on: July 03, 2011, 07:40:57 AM »
vla-put-windowstate ?
Tharwat
  • Hypersensitive
« Reply #2 on: July 03, 2011, 07:50:18 AM »
Perfect . :-)
Thank you Lee .
ribarm
  • Marko Ribar, architect
« Reply #3 on: July 03, 2011, 09:30:07 AM »
I'm sorry, you meant this ?
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-put-windowstate adoc (vlax-make-variant 1))
(vla-put-windowstate adoc (vlax-make-variant 2))
(vla-put-windowstate adoc (vlax-make-variant 3))
M.R.
M.R. on Youtube
Tharwat
  • Hypersensitive
« Reply #4 on: July 03, 2011, 09:38:20 AM »
Thank you ribarm .
That's exactly what I meant and whats Lee brought before .  :-)
I did try it without converting to variant and which would work also like the following .
(vla-put-windowstate (vla-get-activedocument (vlax-get-acad-object)) Acmax ) or Acmin or acnorm
« Reply #5 on: July 03, 2011, 09:49:54 AM »
Depending upon which window you wish to maximise/minimise, either of these will work:
(setq app (vlax-get-acad-object)
      doc (vla-get-activedocument app)
(vla-put-windowstate doc acmin)
(vla-put-windowstate doc acmax)
(vla-put-windowstate doc acnorm)
(vla-put-windowstate app acmin)
(vla-put-windowstate app acmax)
(vla-put-windowstate app acnorm)
ribarm
« Reply #6 on: July 03, 2011, 09:52:45 AM »
Thanks for explanation Tharwat,
that variables Acmax, Acmin, Acnorm actually have values 3, 2, 1... But only after (vl-load-com)
M.R.
M.R. on Youtube
Tharwat
  • Hypersensitive
« Reply #7 on: July 03, 2011, 09:57:01 AM »
Your way of doing it is not mentioned in the Acad Help , so where did you get the inspiration form to convert to variant ?  :-)
It works when converting to variant also . ;-)
