Author Topic: Problem with 'OnClicked' event  (Read 4850 times)
Guest
« on: June 13, 2007, 04:43:15 PM »
For some reason (probably user error on my part) the OnClicked event for a listbox does NOTHING for me.  I'm using version 4.0.1.1.  Is this a "bug" or am I doing something wrong?!?
Below is my code:
(DEFUN C:ODCLTEST ( / )
   (SETQ sVariable "Not set")
   ;; Ensure the OpenDCL.##.ARX is loaded.
   (OR (VL-SYMBOL-VALUE 'ODCL_GETVERSIONEX)
       (AND (SETQ fn (FINDFILE "OpenDCL_ARXLoader.LSP"))
            (LOAD fn (STRCAT "Failed to load :- " fn))
       (ALERT (STRCAT "Failed to load OpenDCL_ARXLoader.LSP"))
       (EXIT)
   ;; Ensure the Project ODC file is loaded.
   (OR (ODCL_PROJECT_LOAD "ODCLTEST") (EXIT))
    ;; Show the dialog
   (ODCL_FORM_SHOW ODCLTEST_Form1)
   (SetUp)
(defun SetUp ( / )
   (Odcl_ListBox_AddString ODCLTEST_Form1_ListBox1 "Item 1")
   (Odcl_ListBox_AddString ODCLTEST_Form1_ListBox1 "Item 2")
   (Odcl_ListBox_AddString ODCLTEST_Form1_ListBox1 "Item 3")
   (Odcl_ListBox_AddString ODCLTEST_Form1_ListBox1 "Item 4")
   (Odcl_ListBox_AddString ODCLTEST_Form1_ListBox1 "Item 5")
(defun c:ODCLTEST_Form1_ListBox1_OnClicked ( /)
   (Odcl_MessageBox "To Do: code must be added to event handler\r\nc:ODCLTEST_Form1_ListBox1_OnClicked" "To do")
Guest
Re: Problem with 'OnClicked' event
« Reply #1 on: June 13, 2007, 04:54:57 PM »
It appears I should be using 'OnSelChanged' instead.  So what's the difference between the two??
« Reply #2 on: June 13, 2007, 05:35:58 PM »
  I'm using version 4.0.1.1.  .................
Is this a typo ?
The corrent build is Beta 16  ( 4.0.1.16 )
Event Clicked
Indicates that the user has clicked the left mouse button on the control.
Parameters: none
Event SelChanged
Indicates that the selection has been changed.
Paramaters: nSelection sSelTex
I don't have time to test the Event Clicked on a ListBox at the moment, but I'll have a look later today. If you have a sample that demonstrated the problem can you post it as a bug at SourceForge.
« Reply #3 on: June 13, 2007, 05:44:39 PM »
Looks to me like your setup is a little out of sequence.
    ;; Show the dialog
   (SetUp)  << this should be in an Form Initialize Event
Once the form is shown ODCL Event trapping takes over so subsequent code is not accessable untill the form is closed.
« Reply #4 on: June 13, 2007, 06:00:30 PM »
You're correct, the OnClicked does not fire. I'll report it ...
added : done https://sourceforge.net/tracker/index.php?func=detail&aid=1736781&group_id=187950&atid=923363
This was the code I tried ..
(DEFUN C:ODCLTEST (/)
    (VL-LOAD-COM)
        (EXIT)
    ;; (ODCL_PROJECT_LOAD "ODCLTEST" T)  ;; to force load the ODC file after mods [kwb]
    ;; Show the dialog
    (PRINC)
(DEFUN c:ODCLTEST_Form1_ListBox1_OnSelChanged (nSelection sSelText /)
    (ODCL_MESSAGEBOX
        "To Do: code must be added to event handler\r\nc:ODCLTEST_Form1_ListBox1_OnSelChanged"
        "To do"
(DEFUN c:ODCLTEST_Form1_ListBox1_OnClicked (/)
    (ODCL_MESSAGEBOX
        "To do"
(DEFUN c:ODCLTEST_Form1_ListBox1_OnRightClick (/)
    (ODCL_MESSAGEBOX
        "To Do: code must be added to event handler\r\nc:ODCLTEST_Form1_ListBox1_OnRightClick"
        "To do"
(DEFUN c:ODCLTEST_Form1_OnInitialize (/)
    (ODCL_LISTBOX_ADDSTRING ODCLTEST_Form1_ListBox1 "Item 1")
    (ODCL_LISTBOX_ADDSTRING ODCLTEST_Form1_ListBox1 "Item 2")
    (ODCL_LISTBOX_ADDSTRING ODCLTEST_Form1_ListBox1 "Item 3")
    (ODCL_LISTBOX_ADDSTRING ODCLTEST_Form1_ListBox1 "Item 4")
    (ODCL_LISTBOX_ADDSTRING ODCLTEST_Form1_ListBox1 "Item 5")
« Last Edit: June 13, 2007, 06:05:54 PM by Kerry Brown »
Guest
« Reply #5 on: June 14, 2007, 08:30:57 AM »
Is this a typo ?
That should've been 4.0.1.11
I just downloaded .16 last night.  I'll have to take a look at it.
Thanks for the 'Form Initialize Event' tip.
