CAD Forums => CAD General => Dynamic Blocks => Topic started by: Fabricio28 on January 21, 2013, 11:10:27 AM
Hey Folks,
I have a dinamic block and I want to add rotate parameter in it.
But I'm having trouble because I don't wanna rotate the texts inside the block, I just want to rotate the rectangle.
Can anyone help me, please?
If I'm thinking right...
Make a 'point move' parameter for the text or anything else you just want to move in a circle (one parameter for each group of objects). In the properties palette, 'chaining' should be 'on' for all of these point move parameters. Then for the rotate parameter, select the only the point move parameters for the texts. Do Not Select The Text!!
yeah, this thread started elsewhere (http://www.theswamp.org/index.php?topic=43615.0)...
Problem solved, guys!
thanks :-D
