Author Topic: Datatables and Datarows.  (Read 4293 times)
tjr
« on: September 07, 2008, 10:20:47 AM »
I'm trying to take multiple datatables and combine them into one "matrix" datatable. Using the code below it fails on the following line:
ndr[tdt.TableName] = dr["qty"].ToString(); Where I had previously set the column name to the table name and now I'm trying to access it.
Any thoughts?
       public DataTable getBomTable2()
            int maxrows = 0;
            DataTable returnDT = new DataTable();
            List<string> tableNames = new List<string>();
            //Loop through each datatable and find the greatest
            //possible row count.
            foreach (DataTable tdt in this.tempDS.Tables)
                if (tdt.Rows.Count > maxrows)
                    maxrows = tdt.Rows.Count;
            //Loop Through each datatable and collect tablenames.
                tableNames.Add(tdt.TableName);
            #region DataColumnAdd
             //Add the BOM columns in reverse order.
            for (int i=0; i < tableNames.Count-1; i++)
                DataColumn dc = new DataColumn();
                dc.DataType = typeof(string);
                dc.ColumnName = tableNames[(tableNames.Count-1) - i].ToString();
                returnDT.Columns.Add(dc);
            //Add all the other DataColumns
            DataColumn catalogCol = new DataColumn();
            catalogCol.DataType = typeof(string);
            catalogCol.ColumnName = "catalogno";
            returnDT.Columns.Add(catalogCol);
            DataColumn partNoCol = new DataColumn();
            partNoCol.DataType = typeof(string);
            partNoCol.ColumnName = "partno";
            returnDT.Columns.Add(partNoCol);
            DataColumn descCol = new DataColumn();
            descCol.DataType = typeof(string);
            descCol.ColumnName = "description";
            returnDT.Columns.Add(descCol);
            DataColumn lenCol = new DataColumn();
            lenCol.DataType = typeof(string);
            lenCol.ColumnName = "blength";
            returnDT.Columns.Add(lenCol);
            DataColumn widCol = new DataColumn();
            widCol.DataType = typeof(string);
            widCol.ColumnName = "bwidth";
            returnDT.Columns.Add(widCol);
            DataColumn remCol = new DataColumn();
            remCol.DataType = typeof(string);
            remCol.ColumnName = "remark";
            returnDT.Columns.Add(remCol);
            DataColumn refCol = new DataColumn();
            refCol.DataType = typeof(string);
            refCol.ColumnName = "ksp";
            returnDT.Columns.Add(refCol);
            #endregion
            //Combine all datatables.
                bool found = false;
                foreach (DataRow dr in tdt.Rows)
                    found = false;
                    foreach (DataRow rdr in returnDT.Rows)
                        if (dr["catalogno"] == rdr["catalogno"] & dr["blength"] == rdr["blength"] & dr["bwidth"] == rdr["bwidth"])
                            found = true;
                            rdr[tdt.TableName] = dr["qty"].ToString();
                    if (found == false)
                        DataRow ndr = returnDT.Rows.Add();
                        ndr["catalogno"] = dr["catalogno"].ToString();
                        ndr["partno"] = dr["partno"].ToString();
                        ndr["description"] = dr["description"].ToString();
                        ndr["blength"] = dr["blength"].ToString();
                        ndr["bwidth"] = dr["bwidth"].ToString();
                        ndr["remark"] = dr["remark"].ToString();
                        ndr["ksp"] = dr["ksp"].ToString();
                        returnDT.Rows.Add(ndr);
            return returnDT;
tjr
Re: Datatables and Datarows.
« Reply #1 on: September 07, 2008, 04:21:24 PM »
Went out and cut the grass, weedwhack etc. and it came to me. Sometimes it's good to take a little break.:
            int maxrows = 0;
            for (int i=0; i < tableNames.Count; i++)
            #endregion
            returnDT.AcceptChanges();
                bool found = false;
                    found = false;
                            found = true;
                    if (found == false)
                        DataRow ndr = returnDT.NewRow();
                        ndr[tdt.TableName.ToString()] = dr["qty"].ToString();
                        found = true;
            DataView obDataView = new DataView(returnDT);
            obDataView.Sort = "partno ASC";
            return this.CreateTable(obDataView);
Draftek
« Reply #2 on: September 09, 2008, 08:11:38 AM »
I'd recommend using sql statements instead of iterating thru database tables. It's much cleaner to maintain and the performance will improve.
Also - I doubt this line is producing the result your expecting:
Glenn R
« Reply #3 on: September 09, 2008, 09:11:55 AM »
I agree on both counts and good catch on the second...nasty gotcha in C based languages.
« Reply #4 on: September 09, 2008, 09:27:22 AM »
Use LinQ
« Last Edit: September 09, 2008, 09:30:27 AM by Daniel »
Glenn R
« Reply #5 on: September 09, 2008, 09:28:56 AM »
Even better idea - what Dan said.
« Reply #6 on: September 09, 2008, 09:36:38 AM »
I’d help with an example but I’m packing for my move to Detroit  :-o
Draftek
« Reply #7 on: September 09, 2008, 09:46:28 AM »
Yeah, thanks. Been meaning to check that out...
Glenn R
« Reply #8 on: September 09, 2008, 09:57:24 AM »
Leaving honkers Dan?
« Reply #9 on: September 09, 2008, 10:18:15 AM »
Yep, The wife got a job as a regional tax manager, they are sending her (and family) to Detroit for training for about 6 months. Then it’s back to this side of the world (Shanghai).
Glenn R
« Reply #10 on: September 09, 2008, 10:20:52 AM »
Travel broadens the mind as they say. Have fun, but the moving sure blows.
tjr
« Reply #11 on: September 09, 2008, 11:26:47 AM »
Hadn't even thought about that. Thanks for the tip.
Yeah I caught that and fixed it the other day.
