I had time today to work on a q&d solution for your plain table to csv routine..It should at least be a good start as its currently incompatible with blocks. Its my convert old table routine, implementing code from fixo's table export routine.
As the merge method used requires that all text be deleted, I cheated by simply performing an undo to replace the text at the end.
Hope you can use it for your final routine.
Sorry for late.
Thanks for your routine,Juan!
I will post my own code tomorrow because some minor matters still exit,for an example,I still failed when bring the color of
the cad text entity to excel text.Others are correct.
My code is stolen from you and fixo.
I think that it will be better when using redraw function to hide the text than delete them and undo.
And,I still cannot understand the meaning of two variables, hmergelist and vmergelist ,such as this list ((0 7 0 6) (0 3 0 2)),
can you explain them in detail?
Next I hope that it will be compatible with blocks.
Your code is a wonderful answer for this topic,Juan,Thanks!
