Author Topic: Hom to lenghten a pipe  (Read 2738 times)
Shibu
« on: January 08, 2014, 03:48:29 PM »
Hi friends,
I want to lengthen a pipe which i inserted in a drawing by 10 inches from the start point. How can i do that.
Please help
Thank you
ChrisCarlson
Re: Hom to lenghten a pipe
« Reply #1 on: January 08, 2014, 04:29:26 PM »
Going to need more info, is it a 3d solid?
Why is this under the .NET?
« Reply #2 on: January 08, 2014, 04:31:34 PM »
From a previous post
This is MEP 2014
Api - .NET
Win – 7-64 Bit
but, yes.
LE3
« Reply #3 on: January 08, 2014, 04:40:47 PM »
in the little I did for mep (2009-2010) the Pipe class have a Length property.
Pipe pipe = tr.GetObject(id, OpenMode.ForRead, false) as Pipe;
if (pipe.Length > 1.0)
HTH
MexicanCustard
« Reply #4 on: January 09, 2014, 08:21:28 AM »
Just change the pipe.StartPoint or the pipe.EndPoint.  Is this a trick question?
Keith Brown
« Reply #5 on: January 09, 2014, 08:38:29 AM »
Here is a quick little example that will add 10" to the end of a pipe.  Please be aware that it will not maintain connection to the next pipe or fitting.
Code - C#: [Select]
  1.
  2. namespace Example_Pipe_Project
  3. {
  4.     public class Class1
  5.     {
  6.         [CommandMethod("PipeLengthenExample", CommandFlags.UsePickSet | CommandFlags.Modal)]
  7.         public static void PipeLengthenExample()
  8.         {
  9.             Pipe pipe = null;
  10.             Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
  11.             var promptSelectOptions = new PromptSelectionOptions();
  12.             promptSelectOptions.MessageForAdding = "Select a Pipe Object:";
  13.             promptSelectOptions.SingleOnly = true;
  14.             PromptSelectionResult promptSelectionResult = editor.SelectByClass(promptSelectOptions, typeof(Pipe));
  15.             if (promptSelectionResult.Status == PromptStatus.OK && promptSelectionResult.Value.Count == 1)
  16.             {
  17.                 try
  18.                 {
  19.                     using (Transaction transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
  20.                     {
  21.                         pipe = (Pipe)transaction.GetObject(promptSelectionResult.Value.GetObjectIds()[0], OpenMode.ForRead, false);
  22.                     }
  23.                     AddToLength(pipe);
  24.                     pipe.Dispose();
  25.                 }
  26.                 catch (System.Exception exception)
  27.                 {
  28.                     editor.WriteMessage(exception.Message);
  29.                 }
  30.             }
  31.             else
  32.             {
  33.                 editor.WriteMessage("\n\nIncorrect type or number of objects selected.");
  34.             }
  35.         }
  36.         private static void AddToLength(Pipe pipe)
  37.         {
  38.             using (Transaction transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
  39.             {
  40.                 try
  41.                 {
  42.                     transaction.GetObject(pipe.ObjectId, OpenMode.ForWrite, false);
  43.                     pipe.Length = pipe.Length + 10;
  44.                     transaction.Commit();
  45.                 }
  46.                 catch (System.Exception exception)
  47.                 {
  48.                     Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(exception.Message);
  49.                 }
  50.             }
  51.         }
  52.     }
  53. }
  54.
Keith Brown
« Reply #6 on: January 09, 2014, 08:43:38 AM »
I agree with MexicanCustard that this is probably the route to go but you will have to get the direction of the pipe (from connector 1 to connector 2) and using that direction calculate your new startpoint or endpoint.
LE3
« Reply #7 on: January 09, 2014, 12:11:13 PM »
the way I read the OP message description was from my old days in acad production and using the command LENGTHEN but to get the pline length on the command line.....
this is something that happens on my current job doing code nowadays - where there is in many cases ZERO explanations or does not lead to anything, no sketches, no drawings, so it takes more time to decipher the task....
a better description to the problem will lead to better responses - instead of end up wasting time.
my 0.2
