Author Topic: to add menu in acad.mnu  (Read 1935 times)
dussla
« on: January 06, 2010, 02:33:42 AM »
i add menu  till pop16 in acad.mnu
but i can;t add any more
what problem
good year   ~
happy always ~~~
Re: to add menu in acad.mnu
« Reply #1 on: January 06, 2010, 03:39:13 AM »
Is 16 already used ??
A Pop menu requires a unique number, depending on what it’s used for:
• For menus that are pulled down from the menu bar, use numbers between 1 and 499.
• For shortcut (right-click) menus, use numbers between 500 and 999.
added:
You may need to post the menu ...
