Save this in your path
I think he meant one of the AutoCAD preference paths - from the Options dialog box.
would I have to put each drawing file name into the script? is there a way to just add a folder?
And you can build a scr file REALLY fast by going to that folder in a DOS prompt, and typing inQuoteDir *.dwg /b /s > MT.scrwhere MT.scr is name of scr file (any name works) Note the spaces in the typing. Then open notepad and Search/Replace the drive letter with open and drive letter, then .dwg with .dwg and rest of scr. Save and runQuoteexample S/Rfind u:\replace w\ Open u:\find .dwgreplace w\ .dwg" (command "-vbarun" "Mario") qsave close
I need to add the initials: KAHN!!!!
