Luis
Thanks,I will play with it.
This is what I'm current using to restore my settings, by Jurg Menzi. I quess I could add in DIMZIN.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Undo Mark Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:UBEG ()
(setvar "CMDECHO" 0)
(setq UNDO_BEGIN T)
(command "UNDO" "BEGIN")
(setvar "CMDECHO" 1)
(princ))
(defun ARCH:UEND ()
(setq UNDO_BEGIN ())
(command "UNDO" "END")
(princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Error Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:ERROR (Msg)
(setvar "cmdecho" 0)
(setq ARCH#DIAP '(-1 -1))
;;(command "_ucs" "");dont use
(setvar "cmdecho" 1)
(if (and Msg (not (eq Msg "quit / exit abort")))
;;(princ Msg)
(princ "\n\n*** ///////// Program CANCELLED ///////// ***\n"))
(ARCH:F_R-VAR)
(princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Clean Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;Jurg Menzi
;;;MENZI ENGINEERING GmbH, Switzerland
;;;http://www.menziengineering.ch
(defun ARCH:F_CLEAN (Lst)
(or Me:Aco (setq Me:Aco (vlax-get-acad-object)))
(or Me:Acd (setq Me:Acd (vla-get-ActiveDocument Me:Aco)))
(vla-StartUndoMark Me:Acd)
(setq Me:Oer *Error*
*Error* ARCH:ERROR)
(mapcar '(lambda (l)
(if (not (assoc l Me:Var))
(setq Me:Var (append Me:Var (list (cons l (getvar l)))))))
Lst)
(princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; F_S-VAR Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:F_S-VAR ()
(ARCH:F_CLEAN
'("APERTURE" "ATTDIA" "ATTREQ" "BLIPMODE" "CECOLOR" "CLAYER" "CELTYPE" "CMDECHO"
"DIMSCALE" "DRAGMODE" "EXPERT" "FILEDIA" "FILLETRAD" "GRIDMODE" "HIGHLIGHT" "LUNITS"
"MENUECHO" "MIRRTEXT" "OFFSETDIST" "ORTHOMODE" "OSMODE" "PICKBOX" "PLINEWID" "REGENMODE"
"SNAPMODE" "SNAPUNIT" "SNAPBASE" "SNAPANG" "SNAPSTYL" "TEXTEVAL" "TEXTSTYLE")))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; F_R-VAR Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;Jurg Menzi
(defun ARCH:F_R-VAR ()
(if Me:Var
(mapcar '(lambda (l) (setvar (car l) (cdr l))) Me:Var))
(setq *Error* Me:Oer
Me:Oer nil
Me:Var nil)
(vla-EndUndoMark Me:Acd)
(princ))
I may go back to hand drafting, this AutCAD stuff makes my head hurt.
Dimzin over and out.
Gary
