Author Topic: Draggable Objects in Dyanamic Block  (Read 1611 times)
MSTG007
« on: May 20, 2014, 10:47:42 AM »
Is it possible to have a dynamic block have other blocks inserted into it. (I am assuming yes!). Now thinking about an Attributed Block and its entity dragablity. Is it possible in a dynamic block to have those block(s) insertion points show up; so I can drag a a specific block within that dynamic block?
Idea, To have an overall dynamic block that has all notes, legends etc. Usually in a sheet file there is 3 or more sheets of the same plan type. If I needed to drag a note over a bit that I could, but it still shows up on all sheets in the original insertion point that I inserted it in to the dynamic block.
Civil3D 2020
Re: Draggable Objects in Dyanamic Block
« Reply #1 on: May 20, 2014, 11:08:42 AM »
I would think you could do it with a point parameter and a move action.
« Last Edit: May 20, 2014, 11:14:12 AM by ronjonp »
MSTG007
« Reply #2 on: May 20, 2014, 11:15:26 AM »
Wow... Sweet. I did not know. Thanks alot
Civil3D 2020
MSTG007
« Reply #3 on: May 20, 2014, 11:16:17 AM »
btw, don't know. but can you reset it? or do you have to re-insert the dyn block?
Civil3D 2020
« Reply #4 on: May 20, 2014, 11:41:56 AM »
Use the RESETBLOCK command.
