Author Topic: same solid size select  (Read 3408 times)
dussla
« on: December 04, 2011, 09:02:37 PM »
hello , good good freind
always good luck
i meet a problem.
that is solid select.
i made a many solid  , but i have  to select  same  volume solid.
is that possible ?
BlackBox
Re: same solid size select
« Reply #1 on: December 05, 2011, 02:39:46 AM »
I would create a selection set of all solids (if present), and prompt the user to select a single desired solid, then iterate the selection set to identify the similar solids and add them to a new selection set then use sssetfirst function.
HTH
ribarm
  • Marko Ribar, architect
« Reply #2 on: December 05, 2011, 05:31:29 AM »
Quick, just like RenderMan proposed :
(defun c:solvolsel ( / ss s1 es1a es1 vol sss n es ) (vl-load-com)
  (setq ss (ssget "_X" (list '(0 . "3DSOLID") (cons 410 (getvar 'ctab))) ))
  (setq s1 (ssget "_:E:S:L" (list '(0 . "3DSOLID") (cons 410 (getvar 'ctab))) ))
  (setq es1a (vlax-ename->vla-object (setq es1 (ssname s1 0))))
  (setq vol (vla-get-volume es1a))
  (setq sss (ssadd))
  (repeat (setq n (sslength ss))
    (setq es (ssname ss (setq n (1- n)) ))
    (if (equal (vla-get-volume (vlax-ename->vla-object es)) vol 1e-8) (ssadd es sss) )
  (ssadd es1 sss)
  (sssetfirst nil sss)
M.R.
M.R. on Youtube
BlackBox
« Reply #3 on: December 05, 2011, 09:34:43 AM »
Cheers, dude. *Tips hat*
Separately, be cautious of this  :wink::
_$ (setq s1 (ssget "_:E:S:L" (list '(0 . "3DSOLID") (cons 410 (getvar 'ctab))) ))
_$ <Right Click>
nil
_$
alanjt
  • Standby for witty remark...
« Reply #4 on: December 05, 2011, 11:16:32 AM »
_$ <Right Click>
nil
_$
Conditionals?!? We don't need no stinking conditionals!
Dropbox
ribarm
« Reply #5 on: December 05, 2011, 11:39:30 AM »
_$ <Right Click>
nil
_$
Yes, conditionals are there to make sure that picked object is 3DSOLID and have Volume property that is checked later on... And for missing to hit an object I agree, just try again...  :roll:
M.R.
« Last Edit: December 05, 2011, 11:42:35 AM by ribarm »
M.R. on Youtube
alanjt
« Reply #6 on: December 05, 2011, 11:41:52 AM »
_$ <Right Click>
nil
_$
M.R.
RM was referring to the use of cond/and/or/if. I was just being myself. :-P
Dropbox
BlackBox
« Reply #7 on: December 05, 2011, 12:07:16 PM »
 :-D
Marko, I'm not sure that I understand.... Are the rolling eyes meant to convey that you understand and/or agree, or that you disagree?  :?
ribarm
« Reply #8 on: December 05, 2011, 01:34:51 PM »
I agree Render, just I am little bit lazy to modify myself...
 :roll:
M.R. on Youtube
BlackBox
« Reply #9 on: December 05, 2011, 01:52:31 PM »
 :roll:
No worries, my friend  :wink:... I can relate.  :lol:
