Code Red => AutoLISP (Vanilla / Visual) => Topic started by: danny on May 23, 2005, 07:51:50 PM
I've seen a routine like this on the Swamp before, just can't seem to find it. Can anyone help? Select all objects on a color and change layer.
Thanks,
Perhaps this one:
http://www.theswamp.org/phpBB2/viewtopic.php?p=39127#39127
CAB,
That is a great routine, and I also like quick select. But, I need to be able to run it in a script file. Sorry, I should have been more specific.
o.k I tried this, but got a bad ssget list. What did I do wrong? Just trying to get all object on color 8 and change them to layer xxfine.
(defun c:c2lay ()
(setq sset
(ssget
"x"
'((62.8))
(if sset
(repeat (sslength sset)
(command "_.chprop" sset "" "layer" "xxfine" "")
'((62.8))
must be:'((62 . 8))
note the spaces...
Cheers
You also have to step thru each item in a selection set using nth.
Try this:
(defun c:c2lay (/ sset len)
(setq sset (ssget "x" '((62 . 8))))
(if sset
(repeat (setq len (sslength sset))
(setq len (1- len))
(command "_.chprop" (nth len sset) "" "layer" "xxfine" "")
ahem...
(if sset
Should be enough
Cheers
Yeah that would work as well. I didn't think of that I just fixed his repeat problem.
So essentially, this is all I need?
(defun c:c2lay ()
(setq sset
(ssget
"x"
'((62 . 8))
(if sset
As long as it's not 'bylayer' :)
Yup!
However it is nice to localize your variables:
(defun c:c2lay (/ sset)
oh darn... Just noticed that too. How can I select colors even if its 'bylayer'?
You need to make a list of layers that are of the color you want to filter.....Someone, coulda even been me, posted something that does this sometime in the past year or so. Lemme check......
OK, here's one I made up that also catches all entities within blocks...... uses ActiveX methods & proporties and no selection set.
After thinking about this, if you want to keep trying your own solution I'm not posting the code here. If you want to see and/or use it, I'm posting it to the Lilly Pond (http://www.theswamp.org/lilly_pond/jeff_m/color2layer.LSP?nossi=1)
Jeff,
I was thinking about trying ActiveX, if plain lisp didn't work. I wish I had enough time to learn this method. Eventually I'll get there...Thanks to the Swamp for everthing, I've become twice as efficient. Well...I do spend a lot of time browsing around in here. :)
So, if I had this list
WHITE = _XBOLD
YELLOW = _BOLD
CYAN = _MED
RED = _FINE
MAGENTA = _XFINE
GREY = _XXFINE
how or where would I input this in your code?
danny, I'd do it by placing each pair of colors/layers into a list, then calling the function in a foreach or mapcar, like this:
(setq colorlist '((7 . "_XBOLD")
(2 . " _BOLD")
(4 . "_MED")
(1 . " _FINE")
(5 . "_XFINE")
(8 . "_XXFINE")
(foreach x colorlist
(color2layer (car x) (cdr x))
hmm. I got an error
Automation Error. Calling method SetObjectId of interface IAcadBaseObject failed
this what I used
(defun color2layer (color layer / atts doc lay lays lokt)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-layers doc)
(if (and (= color (vla-get-color lay))
(not (vl-string-search "|" (vla-get-name lay)))
(setq lays (cons (vla-get-name lay) lays))
(if (eq :vlax-true (vla-get-lock lay))
(setq lokt (cons (vla-get-name lay) lokt))
(vla-put-lock lay :vlax-false)
(vla-startundomark doc)
(setq lay (vla-add (vla-get-layers doc) layer))
(vla-put-color lay color)
(vlax-for blk (vla-get-blocks doc)
(vlax-for ent blk
(if (or (eq (vla-get-color ent) color)
(member (vla-get-layer ent) lays)
(vla-put-layer ent layer)
(if (and (vlax-property-available-p ent "hasattributes")
(vla-get-hasattributes ent)
(setq atts (vlax-invoke ent "getattributes"))
(foreach att atts
(if (or (eq (vla-get-color att) color)
(member (vla-get-layer att) lays)
(vla-put-layer att layer)
(vla-update att)
(if lokt
(foreach lay lokt
(vla-put-lock (vla-item (vla-get-layers doc) lay) :vlax-true)
(vla-endundomark doc)
;;sample usage
(defun c:col2lay ()
(2 . " _BOLD")
(4 . "_MED")
(1 . " _FINE")
(5 . "_XFINE")
(8 . "_XXFINE")
It set "_XBOLD" to all the layers. Forced colors as well as bylayer.[/quote]
hmm. I got an errorAutomation Error. Calling method SetObjectId of interface IAcadBaseObject failed
This is due to there being a leading space in a layer name. Check the list and remove any spaces......I know the list I posted had them, sorry about that, I didn't check it before posting.
this what I used
<snip>
Try it again with the revised list. If it still comes out funky could you email me a portion of the drawing in R2000 format?
cool....Its working.
Much mahalo's Jeff :D
