Author Topic: help with units lisp  (Read 5678 times)
pedroantonio
« on: October 16, 2014, 04:27:51 AM »
Hi . I have a litle problem and a need your help.
My template units is
format --> units
decimal
Grags --> clockwise
meters
genetic
Direction --> North
I use a *.fas file for a long time . The problem is that after "run " the  *.fas file and use it ,change my template units to:
format --> units
decimal
Grags --> clockwise
meters
genetic
Direction --> East
I ask from the gay who write this *.fas to help me and he sent me a file that is not working and giving me an error like this
Command: (LOAD "C:/topocad/GRD.fas") C:GRD
Command: grd
Deleting block "grd".
1 block deleted.
; error: quit / exit abort
I dont know why.
So i want to ask  if is posible to run this *.fas file  through lisp and then to change again the units
I try to write a code
(defun c:test nil
(setq units(getvar "lunits"))
(setvar "lunits" 2) ; decimal
(setq units(getvar "aunits"))
(setvar "aunits" 2) ; grads
(setq units(getvar "angbase"))
(setvar "angbase" 0)
(setq units(getvar "angdir"))
(setvar "angdir" 1) ; clockwise
I dont know how to change the direction to North
Any ideas ?
Thank
kpblc
Re: help with units lisp
« Reply #1 on: October 16, 2014, 04:45:41 AM »
Maybe this code will works:
(defun c:test (/ err)
  (if (vl-catch-all-error-p
        (setq err (vl-catch-all-apply
                    (function
                      (lambda ()
                        (load "C:/topocad/GRD.fas")
                        (command "grd")
                        ) ;_ end of lambda
                      ) ;_ end of function
                    ) ;_ end of vl-catch-all-apply
              ) ;_ end of setq
        ) ;_ end of vl-catch-all-error-p
    (princ (strcat "\n Error loading and executing grd.fas : " (vl-catch-all-error-message err)))
    ) ;_ end of if
  (foreach item '(("lunits" . 2)
                  ("aunits" . 2)
                  ("angbase" . 0)
                  ("angdir" . 1)
                      (function
                        (lambda ()
                          (setvar (car item) (cdr item))
                          ) ;_ end of lambda
                ) ;_ end of setq
      (princ
        (strcat "\n Error settings \""
                (car item)
                "\" SysVar to value "
                (vl-princ-to-string (cdr item))
                ) ;_ end of strcat
        ) ;_ end of princ
      ) ;_ end of if
    ) ;_ end of foreach
  ) ;_ end of defun
Sorry for my English.
« Reply #2 on: October 16, 2014, 05:00:23 AM »
I don't play around with units much, BUT is NORTHDIRECTION variable something to consider ?
pedroantonio
« Reply #3 on: October 16, 2014, 05:01:16 AM »
hi kpblc thank you for your time.
I check your lisp file and gives me this error
Command: (LOAD "C:/Users/Prodromos/Desktop/test.lsp") C:TEST
Command: test
grd Unknown command "GRD".
I can not understand why because the command is the grd
kpblc
« Reply #4 on: October 16, 2014, 06:45:21 AM »
And what will happens if you type "grd" at command line after loading fas by my code?
You can change (command "grd") to one of these:
1. (vl-cmdf "grd")
2. (command-s "grd") ; only at ACAD2015
3. (c:grd).
pedroantonio
« Reply #5 on: October 16, 2014, 11:21:29 AM »
with this change work
                    (function
                      (lambda ()
                        (c:grd)
                        ) ;_ end of lambda
              ) ;_ end of setq
    ) ;_ end of if
                  ("aunits" . 2)
                  ("angbase" . 0)
                  ("angdir" . 1)
                      (function
                        (lambda ()
                          ) ;_ end of lambda
                ) ;_ end of setq
      (princ
                (car item)
                ) ;_ end of strcat
        ) ;_ end of princ
      ) ;_ end of if
    ) ;_ end of foreach
  ) ;_ end of defun
but the direction still East. I want the direction be North
tombu
  • ByLayer=>Not0
« Reply #6 on: October 16, 2014, 01:17:34 PM »
East is the norm, try listing a line and see if it gives you the direction you're looking for.
Tom Beauford P.S.M.
pedroantonio
« Reply #7 on: October 16, 2014, 01:25:35 PM »
My template have the North ath the beginning
Then i run the grd.fas and gives me East
I want to change it again to North when lisp stop .
The test.lsp code gives me East !!!!
How to change it to North ??
« Reply #8 on: October 16, 2014, 01:47:06 PM »
Why don't you change the NORTHDIRECTION system variable as Kerry suggested.
kpblc
« Reply #9 on: October 16, 2014, 03:27:33 PM »
You can add any system variables editing list
'(("lunits" . 2)
                  ("aunits" . 2)
                  ("angbase" . 0)
                  ("angdir" . 1)
Every string is dotpair: first element is system variable name, second - value to be setted. I think is's simplest way.
motee-z
« Reply #10 on: October 16, 2014, 08:23:52 PM »
(defun topodwg (/)
(setvar "angdir"1)
(setvar "angbase"(/ pi 2))
(setvar "aunits"2)
(setvar "dimaunit"2)
  (setvar"dimadec"4)
  (setvar "dimdec"2)
  (setvar "auprec"6)
  (setvar"insunits"6)
kpblc
« Reply #11 on: October 17, 2014, 02:28:15 AM »
I think changing
(setvar "angdir"1)
(setvar "aunits"2)
  (setvar"dimadec"4)
  (setvar "dimdec"2)
  (setvar "auprec"6)
  (setvar"insunits"6)
to
(foreach item (list '("angdir" . 1)
                    (cons "angbase" (/ pi 2))
                    ("aunits" . 2)
                    ("dimaunit" . 2)
                    ("dimadec" . 4)
                    ("dimdec" . 2)
                    ("auprec" . 6)
                    ("insunits" . 6)
                    ) ;_ end of list
  ) ;_ end of foreach
is more simply to undestand and changing in future.
Why do you not use foreach or mapcar functions? It's easy!
Pad
« Reply #12 on: October 17, 2014, 04:26:02 AM »
I simply use two very basic command lisps to change the direction if it ever gets screwed up:
; Lisp to modify drawing so north is 0 and clockwise angles, for some lisp routines
; to work correctly.
; P Bourke (Metrix Surveys) 07/04
(defun C:met-n0 ()
  (setvar "CMDECHO" 0)
  ; change direction to 270 and clockwise to y
  (command "units" "" "" "" "" "90" "y")
(prompt "\n North = 0")
  (setvar "CMDECHO" 1)
; Lisp to modify drawing so East is 0 and clockwise angles, for some lisp routines
(defun C:met-e0 ()
  ; change direction to 0 and clockwise to n
  (command "units" "" "" "" "" "0" "n")
(prompt "\n East = 0")
pedroantonio
« Reply #13 on: October 18, 2014, 04:48:32 AM »
thank you
