Author Topic: How to get the insertion point of a nested block, the easy way?  (Read 6690 times)
LE
« on: October 13, 2005, 10:23:44 AM »
The block can be in any deep form, rotated, scaled, etc, and with a simple selection obtain the insertion point.
- No osnap features.
- No matrix transformation calculations
Dinosaur
Re: How to get the insertion point of a nested block, the easy way?
« Reply #1 on: October 13, 2005, 10:32:23 AM »
grips?
LE
hudster
« Reply #3 on: October 13, 2005, 10:39:51 AM »
Explode block, find insertion point, undo? :-D
LE
« Reply #4 on: October 13, 2005, 10:40:37 AM »
Here is the command for now in FAS mode.
Command: NESTIP
LE
« Reply #5 on: October 13, 2005, 10:44:05 AM »
That is not an easy way....
whdjr
« Reply #6 on: October 13, 2005, 10:55:34 AM »
About 30 seconds...pretty easy to me  8-)
((lambda (/ ent)
   (setq ent (entsel))
   (if ent
     (princ (cdr (assoc 10 (entget (car ent)))))
« Last Edit: October 13, 2005, 11:00:15 AM by whdjr »
« Reply #7 on: October 13, 2005, 10:58:04 AM »
Excellent. Small problem: Doesn't work.
whdjr
« Reply #8 on: October 13, 2005, 10:59:44 AM »
Yeah, I just realized that.
I'll fix.
LE
« Reply #9 on: October 13, 2005, 11:21:09 AM »
It is a max of three lines code.....
Fatty
« Reply #10 on: October 13, 2005, 11:24:23 AM »
Maybe with (vla-get-subentity bla bla)?
F.
LE
« Reply #11 on: October 13, 2005, 11:31:48 AM »
F.
That function will require more than three lines of code.... give it a try.....
vla-getsubentity
whdjr
« Reply #12 on: October 13, 2005, 12:06:53 PM »
Easy...don't put any returns in it... :lmao:
Sorry...couldn't resist... :mrgreen:
« Reply #13 on: October 13, 2005, 12:08:03 PM »
Don't have time to write a proper wrapper for this (i.e. ucs active etc.) but if you select a nested block with the wcs active this should work:
(last (caddr (nentsel)))
LE
« Reply #14 on: October 13, 2005, 12:12:25 PM »
Good.... you da' man
I need to post harder questions...... have fun
