Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Binky on July 16, 2009, 02:57:40 PM
Hello folks,
New State, City, Job, Home, and everything else. Took nearly a year but things have settled down enough to get back to coding so here I am again asking for your guidence.
I am kind of surprised that I have not needed/wanted to do this yet, but here I am trying to find a way to add a value to an existing value inside a list.
original list
(1 2 3 4 5)
I want to add 7 to the 3rd element something like this(only a version that works)
(setq (nth 2 list) (+(nth 2 list) 7))
list afterwards
(1 2 10 4 5 )
I can imagine ways to do this but they all involve creating a new list with the adjusted value. Hoping for a easier solution, just drawing a blank today.
I think I am drawing a blank too...
this is the best I have so far... :|
(defun add (lst i)
(mapcar
(function
(lambda (x)
(if (eq i (vl-position x lst))
(+ 7 x) x))) lst))
(add '(1 2 3 4 5) 2)
(1 2 10 4 5)
You may want to change the order of the arguments, so they flow better.
(defun AddAt ( inList loc num / cnt )
(setq cnt -1)
(mapcar
(function
(lambda ( x )
(setq cnt (1+ cnt))
(if (equal cnt loc)
(+ num x)
x
inList
Command: (AddAt '(1 2 3 4 5) 2 7)
(1 2 10 4 5)
Another, more versatile, function.
(defun PerformAt ( func loc inList / cnt )
(setq cnt -1)
(mapcar
(function
(lambda ( x )
(setq cnt (1+ cnt))
(if (equal cnt loc)
(func x)
x
inList
Command: (performat (lambda (x) (+ 3 x)) 3 '(1 2 3 4 5 6 7))
(1 2 3 7 5 6 7)
(defun test (lst n func)
(if lst
(if (zerop n)
(cons (func (car lst)) (cdr lst))
(cons (car lst) (test (cdr lst) (1- n) func))
;;;(test '(1 2 3 4 5) 2 (lambda (e) (+ e 7)))
;; variation by CAB
(defun adjust_nth (opr num lst i)
(setq i (1+ i))
(mapcar '(lambda (x) (if (zerop (setq i (1- i))) (opr num x) x)) lst)
_$ (adjust_nth + 3 '(1 2 3 4 5 6 7) 4)
(1 2 3 4 8 6 7)
Nice Alan, I've seen you use that method before, in your remove_nth function :-)
I don't understand what you mean Tim :?
Humbled and grateful
Thanks tons!!!!
The way it is written is ' add at list location number '. It might be better written ' add at location number list '. Slight modification, but will sound better when you say it, or think about it. At least I think so.
Ahh, I see :-)
;; variation by CAB
(setq i (1+ i))
(1 2 3 4 8 6 7)
man!
that is clean. bravo.
A different twist on a generic solution, Q+D, coded lean, no error checking etc.
(defun ApplyFooToNth ( [color=red]foo[/color] [color=green]n[/color] [color=blue]lst[/color] )
( (lambda ( bar i ) (mapcar 'bar lst))
(lambda ( a )
(if (eq n (setq i (1+ i)))
(progn (defun bar (a) a) (foo a))
a
-1
Looks verbose but should perform reasonably.
(ApplyFooToNth (lambda (x) (+ 7 x)) 2 '(1 2 3 4 5))
=> (1 2 10 4 5)
Edit: Revised specifically to tease se7en. :)
(defun bar ( a )
(if (eq n (setq i (+ i j)))
a
I think my head just exploded... :laugh:
Nice use of colours though :-)
Binky, where da-hell you been?! Ive tried several times to get a hold of you.
Hows things?
Michael,
I see you use that "Double Defun" trick on this code too:
http://www.theswamp.org/index.php?topic=4903.0 (http://www.theswamp.org/index.php?topic=4903.0) (Great code btw)
But I am having real trouble understanding how it works/is evaluated...
If you have a bit of time, would you be able to shed some light for my confused mind... :-)
Thanks,
Lee
EDIT: just seen you have an explanation on a few pages later in that thread... never mind - I must be blind
...(if (eq n (setq i (+ i j)))
a
hehehe ...nice. I could swear, i had used a redefinition (a quine is an exact reproduction but what would this be called?) recently but i cant for the life of me remember where or why.
Michael, you code needs some fixing
(ApplyFooToNth (lambda (x) (+ 7 x)) 0 '(1 2 3 4 5))
=> (1 2 3 4 12)
You're right vovka, juggling too much here and I combined 2 different approaches. Should have tried it before posting it. :facepalm:
Here's a quick alternate:
(defun ApplyFooToNth ( foo n lst / bar )
(defun bar ( a )
a
((lambda (i) (mapcar 'bar lst)) -1)
(ApplyFooToNth (lambda (x) (+ 7 x)) 0 '(1 2 3 4 5)) => (8 2 3 4 5)
(ApplyFooToNth (lambda (x) (+ 7 x)) 1 '(1 2 3 4 5)) => (1 9 3 4 5)
(ApplyFooToNth (lambda (x) (+ 7 x)) 2 '(1 2 3 4 5)) => (1 2 10 4 5)
(ApplyFooToNth (lambda (x) (+ 7 x)) 3 '(1 2 3 4 5)) => (1 2 3 11 5)
(ApplyFooToNth (lambda (x) (+ 7 x)) 4 '(1 2 3 4 5)) => (1 2 3 4 12)
My apologies peeps and thank you vovka. :)
my version...
(defun f (a b c)
(cond ((not c) c)
((> b 0) (cons (car c) (f a (1- b) (cdr c))))
(t (cons (a (car c)) (cdr c)))
) ;_ cond
test:
(f (lambda (x) (+ 7 x)) 0 '(1 2 3 4 5)) => (8 2 3 4 5)
(f (lambda (x) (+ 7 x)) 2 '(1 2 3 4 5)) => (1 2 10 4 5)
(f (lambda (x) (+ 7 x)) 5 '(1 2 3 4 5)) => (1 2 3 4 5)
OK here is what I think I will end up with, stealing a bit from here and another bit from there.
CAB that was short, sweet and to the point. Nice!
MP, It took me a minute to see the value of redefining the function once the particular index was reached(never would have thought of that myself, thanks for the enlightenment), as it saves time from having to re-evaluate the test condition after the need for it no longer exists. That would save time on large lists.
Tim makes a great point about ordering the arguments for readability, I often forget that.
(defun nthadjust (opr val pos lst / foo)
(defun foo (x)
(if (= pos (setq i (1+ i)))
(defun foo (x) x)
(opr val x))
x))
((lambda (i) (mapcar 'foo lst)) -1)
Thanks everybody
that is the point ... we supply various bits of information that you can decide whether it is useful or not, take the good bits, toss the rest ...
We like to think of it as teaching a man to fish (http://www.theswamp.org/index.php?topic=2621.msg33156#msg33156)
