Author Topic: reactor not reacting on 2011  (Read 2425 times)
Andrea
« on: April 27, 2010, 09:40:29 AM »
Hi all,..
Does anyone had any problem with some reactor on 2011 ?
the code below work good until 2011.
(defun canceltcommand (calling-reactor cancelcommandinfo)
  (if (= (nth 0 cancelcommandinfo) "PLOT")
    (alert "Hello")
(if *canceltcommand*
  (progn (vlr-remove *canceltcommand*)
         (setq *canceltcommand* nil)
(setq *canceltcommand* (vlr-command-reactor nil
                                            '((:vlr-commandcancelled . canceltcommand))
Keep smile...
MeasureUp
Re: reactor not reacting on 2011
« Reply #1 on: April 27, 2010, 06:38:55 PM »
Hi all,..
    (alert "Hello")
Have you checked every functions in your code with the v2011 help?
Maybe there are some functions updated in v2011?
« Reply #2 on: April 27, 2010, 06:48:06 PM »
Andrea, do you get an error, or does the callback just not evaluate?
Andrea
« Reply #3 on: April 28, 2010, 12:08:49 AM »
just nothing happen....
no error....no alert...
i've tried this code on 2010 2008 2007 and work well.
now i'm a little afraid to about using VLisp function..
the commandwillstart ...ended and ....failed work...but not ...cancelled.
If any of you hear about something for this issue...please let me know.
thanks.
Keep smile...
Serge J. Gianolla
« Reply #4 on: April 28, 2010, 12:34:42 AM »
thanks.
Je n'ai pas 2011 mais d'autres personnes ont des soucis avec certains machins dans 2011
http://discussion.autodesk.com/forums/thread.jspa?threadID=770866&tstart=0
