Author Topic: Hatch Object in AutoCAD 2008, a bug or my developing error!  (Read 8598 times)
ReneRam
« on: January 10, 2008, 08:37:45 AM »
Hello everybody,
I'm upgrading some VBA macros for AutoCAD 2004 to .Net in AutoCAD 2008, but I'm having some problems with the Hatch Object.
I've noticed that AutoCAD in the managed environment of Visual Studio 2005 builds the Hatch but some properties are not working.
The PatternScale and The PatternAngle are created with my values, but the display of those objects is not correct. If I check them
through the properties tool or even with a simple "LIST" command, the values are correct but they don't reflect the display.
If I change those values in the editor and reset them as to my values then I get the correct display.
Another thing that's not working correctly is the Area property, that returns always "eInvalidInput" when reading it in the development
environment.
I'm wondering if ti's a bug or if my code is wrong, any help, corrections or hints is appreciated.
Following I'm posting the body of a sample application that recreates the problems.
I'm also attaching the project made for this post, just in case any wants to test it.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Public Class reneramClass
    ' Define command HatchTestA - Square Inside Square with Area = 300
    <CommandMethod("HatchTestA")> _
    Public Sub HatchTestA()
        Dim myPoints As New Geometry.Point3dCollection
        ' Set the points of a 20,20 square
        myPoints.Add(New Geometry.Point3d(0, 0, 0))
        myPoints.Add(New Geometry.Point3d(20, 0, 0))
        myPoints.Add(New Geometry.Point3d(20, 20, 0))
        myPoints.Add(New Geometry.Point3d(0, 20, 0))
        ' Add the 1st square to the drawing
        AddPolyline(myPoints)
        myPoints.Clear()
        ' Set the  points for an internal 10,10 square
        myPoints.Add(New Geometry.Point3d(5, 5, 0))
        myPoints.Add(New Geometry.Point3d(15, 5, 0))
        myPoints.Add(New Geometry.Point3d(15, 15, 0))
        myPoints.Add(New Geometry.Point3d(5, 15, 0))
        ' Add the 2nd square to the drawing
        ' Create the Hatch
        Dim mySS As Autodesk.AutoCAD.EditorInput.SelectionSet
        mySS = SSLayer("0")
        ' Start debug here:
        '       Hatch(Area Is 300)
        '       Hatch Representation is not correct:
        '       Pattern Scale is "1" but looking in the properties through the editor
        '       it's reported as "0.5"
        '       Patern Angle is "0" but looking n the properties through the editor
        '       it's reported as "58"
        AddHatch(mySS, , 0.5, 45.0, , True)
    End Sub
    ' Define command HatchTestB - Square Intersecting Square with Area = 400
    <CommandMethod("HatchTestB")> _
    Public Sub HatchTestB()
        myPoints.Clear()
        ' Set the  points for an intersecting 10,10 square
        myPoints.Add(New Geometry.Point3d(25, 5, 0))
        myPoints.Add(New Geometry.Point3d(25, 15, 0))
        ' Create the Hatch
        mySS = SSLayer("0")
        ' Start debug here:
        '       Hatch(Area Is 400)
    End Sub
    ' Define command HatchTestC - Two separate Squares with total Area = 500
    <CommandMethod("HatchTestC")> _
    Public Sub HatchTestC()
        myPoints.Clear()
        ' Set the  points for an external 10,10 square
        myPoints.Add(New Geometry.Point3d(35, 5, 0))
        myPoints.Add(New Geometry.Point3d(45, 5, 0))
        myPoints.Add(New Geometry.Point3d(45, 15, 0))
        myPoints.Add(New Geometry.Point3d(35, 15, 0))
        ' Create the Hatch
        mySS = SSLayer("0")
        ' Start debug here:
        '       Hatch(Area Is 500)
    End Sub
    ' Add a Polyline
    Sub AddPolyline(ByVal PlinePoints As Geometry.Point3dCollection)
        Dim myTransMan As DatabaseServices.TransactionManager
        Dim myTrans As DatabaseServices.Transaction
        Dim myDWG As ApplicationServices.Document
        Dim myBT As DatabaseServices.BlockTable
        Dim myBTR As DatabaseServices.BlockTableRecord
        'Get the active document and begin a Transaction
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myTransMan = myDWG.TransactionManager
        myTrans = myTransMan.StartTransaction
        'Open the BlockTable for Read
        myBT = myDWG.Database.BlockTableId.GetObject( _
            DatabaseServices.OpenMode.ForRead)
        myBTR = myBT(DatabaseServices.BlockTableRecord.ModelSpace).GetObject( _
            DatabaseServices.OpenMode.ForWrite)
        ' Draw the Polyline
        Dim myPLine As New DatabaseServices.Polyline2d(Poly2dType.SimplePoly, _
                PlinePoints, 0, True, 0, 0, Nothing)
        myBTR.AppendEntity(myPLine)
        myTrans.AddNewlyCreatedDBObject(myPLine, True)
        'Commit the Transaction
        myTrans.Commit()
        myTrans.Dispose()
        myTransMan.Dispose()
    End Sub
    ' Add a Hatch
    Sub AddHatch(ByVal HatchLoops As Autodesk.AutoCAD.EditorInput.SelectionSet, _
                Optional ByVal HatchPattern As String = "ANSI31", _
                Optional ByVal HatchScale As Double = 1, _
                Optional ByVal HatchAngle As Double = 0, _
                Optional ByVal ACIColor As Short = 256, _
                Optional ByVal HatchIsAssociative As Boolean = True)
        Dim myDB As DatabaseServices.Database
        Dim myTrans As Transaction
        Dim myEd As EditorInput.Editor
        Dim myObjIds As DatabaseServices.ObjectIdCollection
        Dim myObjId As DatabaseServices.ObjectId
        Dim myHatch As Hatch        'the hatch object
        Dim myHatchLoops As ObjectIdCollection  ' collection of IDs of the hatch loops
        Dim HatchArea As Double     'place holder for messagebox
        myDB = myDWG.Database
        myEd = myDWG.Editor
        ' Get the IDs of the hatch loops
        myObjIds = New ObjectIdCollection(HatchLoops.GetObjectIds)
        ' build the hatch
        Try
            ' open the block table for read
            myBT = myTrans.GetObject(myDB.BlockTableId, OpenMode.ForRead)
            ' create block table record for write
            myBTR = myTrans.GetObject(myBT(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            ' create the hatch
            myHatch = New Autodesk.AutoCAD.DatabaseServices.Hatch
            ' add newly created hatch to block table record
            myBTR.AppendEntity(myHatch)
            ' add the hatch BTR to the BT
            myTrans.AddNewlyCreatedDBObject(myHatch, True)
            ' set hatch properties
            ' Pattern
            myHatch.SetHatchPattern(HatchPatternType.PreDefined, HatchPattern)
            ' Hatch Pattern Scale
            myHatch.PatternScale = HatchScale
            ' Hatch Pattern Angle
            myHatch.PatternAngle = HatchAngle
            ' Color
            myHatch.ColorIndex = CInt(ACIColor)
            myHatch.Normal = New Geometry.Vector3d(0, 0, 1)
            myHatch.Elevation = 0.0
            ' Hatch is Associative
            If HatchIsAssociative Then
                myHatch.Associative = True  ' hatch is associative
            End If
            ' append hatch loops
            For Each myObjId In myObjIds
                myHatchLoops = New ObjectIdCollection
                myHatchLoops.Add(myObjId)
                myHatch.AppendLoop(HatchLoopTypes.Default, myHatchLoops)
            Next
            ' Update the newly created hatch
            myHatch.EvaluateHatch(False)
            'Get the Hatch Area
            ' Comment the following line when testing Hatch Scale
            HatchArea = myHatch.Area    '<= eInvalidInput error
            myTrans.Commit()
            myBT.Dispose()
            myBTR.Dispose()
        Catch ex As System.Exception
            MsgBox(ex.Message)      '<= eInvalidInput Message
            ' Add the hatch in any case
            myTrans.Commit()
        Finally
            myEd.Regen()
            myTrans.Dispose()
        End Try
        ' Display Hatch Area
        MsgBox(HatchArea, MsgBoxStyle.Information, "Hatch Area")
    End Sub
    ' Get SelectionSet of a Layer
    Function SSLayer(ByVal LayerName As String) As EditorInput.SelectionSet
        Dim myPSR As EditorInput.PromptSelectionResult
        Dim myFilter(0) As DatabaseServices.TypedValue
        myFilter(0) = New DatabaseServices.TypedValue( _
            DatabaseServices.DxfCode.LayerName, LayerName)
        Dim mySF As New EditorInput.SelectionFilter(myFilter)
        myEd = myDWG.Editor
        myPSR = myEd.SelectAll(mySF)
        SSLayer = myPSR.Value
        myTrans.Commit()
        myTrans.Dispose()
        Return SSLayer
    End Function
End Class
Thanks in advance for any help!
René
David Hall
  • Automatic Duh Generator
Re: Hatch Object in AutoCAD 2008, a bug or my developing error!
« Reply #1 on: January 11, 2008, 09:01:26 AM »
Welcome to theswamp Rene.  I haven't learned the hatch object in .Net yet, but Im sure someone who has will be along soon
ReneRam
« Reply #2 on: January 11, 2008, 10:11:16 AM »
Just an update, I still haven't solved the issue, but i found this:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2895532&linkID=9240617
in the Autocad Service and Support site. It states that it afects only AutoCAD 2000-2002, but in my Auocad 2008 and in the beta of 2009, I still have the same result.
René
ReneRam
Another small update for anyone interestedd in the topic.
« Reply #3 on: January 14, 2008, 07:44:08 AM »
I wrote a little workaround to part of the problem:
it concerns only the Pattern display problems, it's what I call a dirty solution, but at the moment it fits.
I'm calling a small external LISP function:
(defun updHtch ()
  (setq SS (ssget "x" '((0 . "HATCH"))))
  (setq cnt (sslength SS))
  (setq cnt1 0)
  (while (< cnt1 cnt)
    (setq ent (ssname SS cnt1))
    (setq Vlent (vlax-ename->vla-object ent))
    (if (vlax-property-available-p Vlent 'PatternScale)
(setq pscale (vla-get-PatternScale Vlent))
(vlax-put-property Vlent 'PatternScale pscale)
(vlax-invoke Vlent 'Evaluate)
    (setq cnt1 (+ 1 cnt1))
  (command "_regen")
Sorry I didn't add comments but if anyone needs I'll put down some.
I'm also posting an updated version of the Visual Studio Project.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: January 14, 2008, 08:09:03 AM »
Hi René, Welcome to TheSwamp.  :-)
Sorry I couldn’t be of help, I read VB about as well I read tea leaves.  :oops:
Thanks for sharing your solution
Bryco
« Reply #5 on: January 14, 2008, 10:18:16 AM »
Does the problem happen with polylines (I notice you use 2dpolies)
Does the area work after the hatch has been committed.
(Sorry i dont have a vb editor)
ReneRam
« Reply #6 on: January 14, 2008, 10:54:49 AM »
Yes, the problem happens in any case, that's why I thought it could be my error, Maybe there's a better way to create the hatch, but in the program that I'm developing I can select a hatch object created with AutoCAD environment normally, not programming, and when modifying it or trying to retrieve the area I get the same kind of problem: "eInvalidInput" when reading the area and pattern display not updated when changed.
I'm wondering if it's a wrong approach to the problem or if it's just that "acmgd.dll" simply doesn't support completely the object.
Maybe there are developers that use ObjectArx in C++ that interact directly with the API that don't have this kind of problem, but I don't have that knowledge. I've posted the question of the "Area" in the ".Net" discussion group of Autodesk, but with no replies. I guess the problem is only mine or nobody has found a solution 'till now.
In any case I'm still trying to figure out a solution and as soon I get one I'll post it here as a memory to others.
In any case, after the hatch has been created with my sample, as I said in my first post, you can simply "list" it to read the area.
Here's the code.
        myPoints.Clear()
        ' Create the Hatch
        mySS = SSLayer("0")
        ' Start debug here:
        ' LISP WorkAround
        UpdHatchDisplay()
    End Sub
        myPoints.Clear()
        ' Create the Hatch
        mySS = SSLayer("0")
        ' Start debug here:
        ' LISP WorkAround
        UpdHatchDisplay()
    End Sub
        myPoints.Clear()
        ' Create the Hatch
        mySS = SSLayer("0")
        ' Start debug here:
        ' LISP WorkAround
        UpdHatchDisplay()
    End Sub
    ' Add a Polyline
        ' Draw the Polyline
        myTrans.Commit()
        myTrans.Dispose()
    End Sub
    ' Add a Hatch
        ' Angle must be Updated to current units
        Dim strHtcAngle As String = CStr(HatchAngle)
        HatchAngle = Converter.StringToAngle(strHtcAngle, AngularUnitFormat.Current)
        myEd = myDWG.Editor
        ' build the hatch
        Try
            ' create the hatch
            ' Pattern
            ' Color
            End If
            Next
            'Get the Hatch Area
            myTrans.Commit()
            myBT.Dispose()
            myBTR.Dispose()
            myTrans.Commit()
        Finally
            myEd.Regen()
            myTrans.Dispose()
        End Try
    End Sub
        myEd = myDWG.Editor
        myTrans.Commit()
        myTrans.Dispose()
        Return SSLayer
    End Function
    ' Update Hatch Display - Workaround in LISP
    Sub UpdHatchDisplay()
        myEd = myDWG.Editor
        Dim cmdString As String
        cmdString = "(load " & Chr(34) & _
            "C:/Temp/UpdHatch.lsp" & _
            Chr(34) & ") (updHtch) "
        ' Run Lisp patch
        myDWG.SendStringToExecute(cmdString, True, False, False)
        myTrans.Commit()
        myTrans.Dispose()
    End Sub
End Class
René
Fatty
« Reply #7 on: January 14, 2008, 11:23:07 AM »
Try this quick example, tested on A2008eng only
    Public Sub MakeHatch()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim adoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim doclock As DocumentLock = adoc.LockDocument
        adoc.LockDocument(DocumentLockMode.Write, Nothing, Nothing, True)
        Using tr As Transaction = db.TransactionManager.StartTransaction
            Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Try
                Dim res As PromptEntityResult = ed.GetEntity(ControlChars.Lf & "Select entity to be hatch:")
                If res.Status <> PromptStatus.OK Then
                    Return
                End If
                Dim ent As Entity = tr.GetObject(res.ObjectId, OpenMode.ForRead, False)
                Dim ids As ObjectIdCollection = New ObjectIdCollection
                ids.Add(res.ObjectId)
                Dim hatchType As HatchPatternType = New Autodesk.AutoCAD.DatabaseServices.HatchPatternType
                Dim patName As String = "ANSI32"
                hatchType = CType(Autodesk.AutoCAD.DatabaseServices.HatchPatternType.PreDefined, Integer)
                Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim hatchObj As New Hatch
                btr.AppendEntity(hatchObj)
                tr.AddNewlyCreatedDBObject(hatchObj, True)
                With hatchObj
                    .UpgradeOpen()
                    .HatchStyle = Autodesk.AutoCAD.DatabaseServices.HatchStyle.Outer
                    .Associative = True
                    .Layer = "0"
                    .ColorIndex = 34
                    .PatternAngle = Math.PI / 2
                    .PatternScale = 250.0
                    .PatternSpace = 250.0
                    ' keep this order to set pattern at the end!
                    .SetHatchPattern(hatchType, patName)
                    .DowngradeOpen()
                End With
                hatchObj.AppendLoop(HatchLoopTypes.External, ids)
                hatchObj.EvaluateHatch(True)
                ed.Regen()
                tr.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(ex.StackTrace)
            Finally
                tr.Dispose()
            End Try
        End Using
        doclock.Dispose()
    End Sub
ReneRam
« Reply #8 on: January 15, 2008, 05:47:25 AM »
Very Clever,
thanks a lot your code works perfectly. I see that my error was in the order of assigning and evaluating the properties and the loops to the hatch object.
I noticed that you specified that the loops are External. A further question, just to clarify a doubt. Reading the ObjectArx documentation I found that the loops specified as Default are:
The loop type hasn't been specified yet. It turns to a "real" value as soon as some real loops get created
and coming from VBA development I thought the value simply updated by it self, a I wrong?
René
Fatty
« Reply #9 on: January 15, 2008, 01:35:33 PM »
Hi René,
here is this example from ObjectARX documentation
you had talking about
It will works with newly created objects both external
contour and inner islands
As you could see it will work without SetDefaults:
    Sub addhatch()
        Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
        Dim docklock As DocumentLock = doc.LockDocument()
        Dim db As Database = HostApplicationServices.WorkingDatabase()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor()
        Dim tr As Transaction = db.TransactionManager.StartTransaction
        Dim pHatch As New Hatch
        btr.AppendEntity(pHatch)
        tr.AddNewlyCreatedDBObject(pHatch, True)
        'Set hatch plane, normal, elevation
        Dim norm As Vector3d = New Vector3d(0.0, 0.0, 1.0)
        pHatch.Normal = norm
        pHatch.Elevation = 0.0
        'Set hatch pattern to ANSI31 predefined type
        pHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
        'Set Associativity
        pHatch.Associative = True
        'Construct database AcDbLines
        Dim vertexPts(3) As Point3d
        'Dim lineId As ObjectId, cirId As ObjectId, hatchId As ObjectId
        Dim dbObjIds As ObjectIdCollection = New ObjectIdCollection
        Dim line As Line
        vertexPts(0) = New Point3d(2.0, 2.0, 0.0)
        vertexPts(1) = New Point3d(8.0, 2.0, 0.0)
        vertexPts(2) = New Point3d(8.0, 8.0, 0.0)
        vertexPts(3) = New Point3d(2.0, 8.0, 0.0)
        For i As Integer = 0 To 3
            line = New Line
            line.StartPoint = vertexPts(i)
            If i = 3 Then
                line.EndPoint = vertexPts(0)
            Else
                line.EndPoint = vertexPts(i + 1)
            End If
            btr.AppendEntity(line)
            tr.AddNewlyCreatedDBObject(line, True)
            dbObjIds.Add(line.ObjectId)
        Next
        'Append an external rectangular loop to hatch boundary
        pHatch.AppendLoop(HatchLoopTypes.External, dbObjIds)
        'Create a AcDbCircle and post it to database
        Dim cenPt As Point3d = New Point3d(5.0, 5.0, 0.0)
        Dim cnorm As Vector3d = New Vector3d(0.0, 0.0, 1.0)
        Dim circle As Circle = New Circle()
        circle.Normal = cnorm
        circle.Center = cenPt
        circle.Radius = 1.0
        btr.AppendEntity(circle)
        tr.AddNewlyCreatedDBObject(circle, True)
        dbObjIds.Clear()
        dbObjIds.Add(circle.ObjectId)
        'Append an internal loop (circle) to hatch boundary
        pHatch.AppendLoop(HatchLoopTypes.Default, dbObjIds)
        'Elaborate hatch lines
        pHatch.EvaluateHatch(True)
'// here was omitted the part of code about [b]setPersistenRactor[/b] method
'// I don't know how to use this method in pure VB.NET
        tr.Commit()
    End Sub
Another one will works with already created objects
just select at the first the contour object and then
all the inner islands inside:
  Public Shared Sub MakeHatch()
            Dim res As PromptEntityResult = ed.GetEntity(ControlChars.CrLf & "Select entity to be hatch:")
                Return
            End If
            Dim eds As ObjectIdCollection = SelectOnscreenEx()
            MsgBox(eds.Count.ToString)
            Dim patName As String = "BRICK"
            hatchObj.Normal = norm
            hatchObj.Elevation = 0.0
            With hatchObj
                .UpgradeOpen()
                .HatchStyle = Autodesk.AutoCAD.DatabaseServices.HatchStyle.Normal
                .Associative = True
                .Layer = "0"
                .ColorIndex = 12
                .PatternAngle = 0.0 'Math.PI / 2
                .PatternScale = 4.0
                .PatternSpace = 4.0
            End With
            For Each id As ObjectId In eds
                ids.Clear()
                ids.Add(id)
                hatchObj.AppendLoop(HatchLoopTypes.Default, ids)
            Next
            ed.Regen()
            tr.Commit()
        End Using
        doclock.Dispose()
    End Sub
    Public Shared Function SelectOnscreenEx() As ObjectIdCollection
        Dim dxf() As TypedValue = {New TypedValue(DxfCode.Start, "*")}
        Dim filt As New SelectionFilter(dxf)
        Dim opts As PromptSelectionOptions = New PromptSelectionOptions
        opts.MessageForAdding = ControlChars.CrLf & "Select the inner islands:"
        opts.AllowDuplicates = False
        opts.SingleOnly = False
        Dim res As PromptSelectionResult = ed.GetSelection(opts, filt)
            Return Nothing
        End If
        Dim sset As SelectionSet = res.Value
        Dim IDs() As ObjectId = sset.GetObjectIds
        Dim idcol = New ObjectIdCollection
        For Each id As ObjectId In IDs
            idcol.Add(id)
        Next
        Return idcol
    End Function
Sorry I can't explain you more, that's
out of my C++ skills, but I hope it will helps
Of course this was written too quickly as the
my prior code above, by this reason test it by yourself
extensively
Happy computing :)
~'J'~
