Author Topic: How to select dim style using active x. Help!  (Read 1335 times)
abe123456789
« on: April 19, 2022, 10:31:43 PM »
I created a line using vla-Addline and then used vla-addDimaligned  to add a dimension but I cannot figure out how to select which dimensions I want to use.
I want to make 2 dimension above and below the line. I have the 2 dimension style to do so but i can only use the current selected dimstyle.
(defun c:UGP (/ start end line1 dim1 a)
  (setq Start (getpoint "\nStart point of path: "))
  (setq end (getpoint start "\nEndpoint of path: "))
(setq *ModelSpace*
      (vla-get-ModelSpace
        (vla-get-ActiveDocument (vlax-get-acad-object))
(setq line1
        (vla-Addline
          *ModelSpace*
          start end
(vla-AddDimAligned *ModelSpace* start end end))
BIGAL
  • 40 + years of using Autocad
Re: How to select dim style using active x. Help!
« Reply #1 on: April 20, 2022, 12:31:38 AM »
Try
(command "dimstyle" "r" "yourdimstyle")
abe123456789
« Reply #2 on: April 20, 2022, 08:35:47 AM »
I have tried that can’t figure it out
« Reply #3 on: April 20, 2022, 10:26:43 AM »
You need to get your code working before you go onto the next task.
mhupp
« Reply #4 on: April 20, 2022, 11:34:42 AM »
are you trying to switch to a dimstyle that isn't loaded/saved?
  1. (if (tblsearch "DIMSTYLE" "stylename")
  2.   (command "-dimstyle" "restore" "stylename")
  3.   (princ "\nDimstyle not found")
  4. )
abe123456789
« Reply #5 on: April 20, 2022, 12:46:10 PM »
Im trying to Draw a line then dim that line with 2 existing dim that are on the document.
mhupp
« Reply #6 on: April 20, 2022, 03:38:17 PM »
Prob be easier to upload a drawing with the line and dimensions you want.
----Edit why two dims? why not use primary/secondary in one dim?
abe123456789
« Reply #7 on: April 20, 2022, 10:51:11 PM »
How would you do that with one dim?
mhupp
