Author Topic: Reload Linetype in accadoc.lsp ?  (Read 3359 times)
Zykl0
« on: July 20, 2015, 12:27:02 PM »
Hello,
I am trying to reload every linetype automaticly when I open a drawing according to the drawing measurement units.
The two first line (insunits and snapunit) work flawlessly, however the reload linetype doesn't work.
Any workaround?
(cond ((= (getvar "MEASUREMENT") 0) ;MEASUREMENT=0 (inches)
            (setvar "insunits" 1)
            (command "snapunit" "12,12")
            (command "._linetype" "_load" "*" "acad" "")
           ((= (getvar "MEASUREMENT") 1) ;MEASUREMENT=1 (millimeters)
            (setvar "insunits" 4)
            (command "snapunit" "300,300")
            (command "._linetype" "_load" "*" "acadiso" "")
     ) ;_ cond
roy_043
  • BricsCAD 18
Re: Reload Linetype in accadoc.lsp ?
« Reply #1 on: July 20, 2015, 12:34:02 PM »
You will have to loop over the line types that are already defined.
You can use the (tblnext "ltype" ...) for that.
Zykl0
« Reply #2 on: July 20, 2015, 12:39:34 PM »
Doesn't work, maybe I do it wrong?
            (tblnext "ltype")
            (tblnext "ltype")
     ) ;_ cond
roy_043
  • BricsCAD 18
« Reply #3 on: July 20, 2015, 12:44:10 PM »
Coding is more than copy+paste. Why don't you study the mentioned function first.
« Reply #4 on: July 20, 2015, 12:45:12 PM »
I use this
  1. (COMMAND "EXPERT" 5 "LINETYPE" "L" "*" "ACADiso" "" )
Zykl0
« Reply #5 on: July 20, 2015, 12:49:02 PM »
the command (command "._linetype" "_load" "*" "acadiso" "") or (COMMAND "EXPERT" 5 "LINETYPE" "L" "*" "ACADiso" "" ) work flawlessly in a macro, in another lisp or directly in the command prompt. I don't get it why it doesn't work in acadoc.lsp
« Reply #6 on: July 20, 2015, 12:54:54 PM »
(command "._linetype" "_load" "*" "acadiso" "")  will only work if you're not redefining existing linetypes ... otherwise it will prompt "Linetype "SomeLineTypeName" is already loaded.  Reload it? <Y> y". Use Kerry's suggestion.
« Reply #7 on: July 20, 2015, 01:04:25 PM »
Try the following in your acaddoc.lsp:
  1. (defun ltredef ( / lin val var )
  2.     (setq var '(cmdecho expert)
  3.           val  (mapcar 'getvar var)
  4.           lin  (if (zerop (getvar 'measurement)) "acad" "acadiso")
  5.     )
  6.     (mapcar 'setvar var '(0 5))
  7.     (command "_.-linetype" "_L" "*" lin "")
  8.     (mapcar 'setvar var val)
  9.     (princ)
  10. )
  11. (if (= 'list (type s::startup))
  12.     (setq s::startup (append s::startup '((ltredef))))
  13.     (defun-q s::startup nil (ltredef))
  14. )
The above is untested.
« Reply #8 on: July 20, 2015, 01:09:11 PM »
<...> I don't get it why it doesn't work in acadoc.lsp
That exact (my) code is from a file that is used daily by several offices and has been for at least 10 years.
I just now added it to an acaddoc.lsp and it works without fail on several test drawings
« Reply #9 on: July 20, 2015, 01:22:05 PM »
I use this
Hate stepping on toes but if going the simplified route may I suggest:
(command "cmdecho" 0 "expert" 5 ".linetype" "_L" "*" "ACADiso" "" "expert" 0 "cmdecho" 1)
« Reply #10 on: July 20, 2015, 01:36:52 PM »
Hi Michael,
No fear !
I do all my housekeeping before and after that call ... but yes, housekeeping is needed.
« Reply #11 on: July 20, 2015, 01:54:02 PM »
I've no doubt, I recognize the snip is but one line from likely hundreds or more.
Cheers!
roy_043
  • BricsCAD 18
« Reply #12 on: July 21, 2015, 03:24:35 AM »
I didn't know about the use of "EXPERT" in this context. But I have also misinterpreted the word 'reload' in the OP. So there actually are people out there who want ALL linetypes from acad(iso).lin in their drawings... :-o
