Author Topic: Invalid option keyword  (Read 3735 times)
2e4lite
« on: May 17, 2014, 10:23:19 PM »
      (setq ent (ssname ss n))
      (command "chprop" ent "" "la" lay_chname "")
   It runs successfully in cad2004,but in cad2009, prompting Invalid option keyword,why?
Re: Invalid option keyword
« Reply #1 on: May 17, 2014, 10:39:13 PM »
Perhaps the command prompt sequence has changed ... if all other things are equal.
2e4lite
« Reply #2 on: May 17, 2014, 10:54:56 PM »
If I operate  step by step  in  the command line by this sequence,It is also successful
« Last Edit: May 17, 2014, 11:22:43 PM by 2e4lite »
« Reply #3 on: May 18, 2014, 06:21:19 AM »
Try:
(command "_.chprop" ent "" "_layer" lay_chname "")
2e4lite
« Reply #4 on: May 18, 2014, 07:35:32 AM »
Thanks Kerry and  Lee Mac !
irneb
« Reply #5 on: May 20, 2014, 06:42:57 AM »
Try:
Moral of the story ... never use shortcuts for options when calling them from Lisp (use the full option's name). You can be nearly 100% sure something will change again if any new option is added in a later version, and the chance that that "something" is the shortcut is very high - while the name is much less probable.
