Author Topic: Wipeouts not wiping  (Read 2203 times)
whdjr
Wipeouts not wiping
« on: December 21, 2005, 07:49:55 AM »
Does anyone use wipeouts?
I know in previous releases of AutoCad there was a problem with wipeouts not maintaining draworder in a viewport.  I am still having this issue in 2006.
Can someone else out there in 2006 verify this for me?
Re: Wipeouts not wiping
« Reply #1 on: December 21, 2005, 09:07:05 AM »
I still have problems with them at times (AutoCAD 2005).
PHX cadie
« Reply #2 on: January 10, 2006, 01:18:25 PM »
I never had a problem till today (Ver 05)
When using "text mask" on a single text the text seems to have been deleted. I window the area to do a draworder and only the line is selected, like the text is gone.
Text mask on a Mtext is no problem.
I just changed all these labels from Mtext to Dtext, (I like changing the text then slam the return button) now I gatta go back  :-(
Ideas?
<edit>
(Hope I didn't steal your thread, I'm thinkin of text mask the same as a wipeout)
Along those lines:
Why does mask "sometimes" move with a text, sometimes not?. It can be very irratating to find out a mask has been astray. No wipeouts should be left behind (note to self: need camo smiley)
« Last Edit: January 10, 2006, 01:29:12 PM by WannaBeCader »
Acad 2013 and XM
Back when High Tech meant you had an adjustable triangle
Gliderider
« Reply #3 on: January 10, 2006, 02:26:24 PM »
Along those lines:
If you set "pickstyle" to 3, the mask will follow the text when you move the text.
pmvliet
« Reply #4 on: January 10, 2006, 03:14:28 PM »
I like that  :-D
you would think a textmask would know it's boundary and take it with itself without chaging a variable.
and I don't know how "Pickstyle" would control a textmask boundary unless it is treating it like a hatch...
Type: Integer
Saved in: Registry
Initial value: 1
Controls the use of group selection and associative hatch selection.
0  No group selection or associative hatch selection
1   Group selection
2   Associative hatch selection
3   Group selection and associative hatch selection
PHX cadie
« Reply #5 on: January 10, 2006, 03:29:07 PM »
Pickstyle seems to work!
Thanks All
Ideas about the dfference between Dtext and Mtext, I'd almost swear I've masked both without a problem?
« Last Edit: January 10, 2006, 03:34:41 PM by WannaBeCader »
Acad 2013 and XM
Gliderider
« Reply #6 on: January 11, 2006, 07:15:03 AM »
Type: Integer
Saved in: Registry
Initial value: 1
1   Group selection
The mask moves with text when pickstyle=1 so it must treat it like a group
PHX cadie
« Reply #7 on: January 11, 2006, 11:22:31 AM »
Dif day...dif dwg
Just did a Text Mask on Dtext w/o a problem, (I don't understand)  :cry:
Acad 2013 and XM
Barry Clark
« Reply #8 on: January 17, 2006, 08:08:11 AM »
Could be because PICKSTYLE is a system and not a document variable. If you adjust it, then it stays where you set it globally until you change it. It doesn't change from drawing to drawing.
PHX cadie
« Reply #9 on: January 17, 2006, 02:48:35 PM »
Pickstyle was the trick as far as the mask moving with the text, so that prob is solved, but I still have the problem of Text Mask that works with Mtext but seems to delete the same line when it is a sinlge line text.
I'll try another dwg
Acad 2013 and XM
drizzt
« Reply #10 on: January 18, 2006, 11:14:53 AM »
I have had the same problem with wipeouts, but only when I plot. To the plotter, to dwf or anything.
