Author Topic: Change Insertion Point of an Image  (Read 3077 times)
M-dub
« on: December 22, 2011, 08:51:04 AM »
I have a user who wants the insertion point of an image to be the Top-Centre of the image.  I'd never heard of such a request.  For a block, it's easy.  For an image, I just told him to turn the frame on and move it using the midpoint of the top frame to its destination... meh...
Just thought I'd ask.
Rob...
Re: Change Insertion Point of an Image
« Reply #1 on: December 22, 2011, 09:06:16 AM »
Make a block out of it.
CAD Tech
M-dub
« Reply #2 on: December 22, 2011, 09:11:50 AM »
:-D
That's what I told him.
He was hoping that there was a default setting that you could change from bottom-left to top-centre.
« Reply #3 on: December 22, 2011, 10:10:29 AM »
What you should have told him:
Command: move
1 found
Specify base point or [Displacement] <Displacement>:   _m2p First point of mid:
  _int of Second point of mid: _int of
Specify second point or <use first point as displacement>:
The _Intersections being selected in the command sequence above are the corners of the image in question.
Then have a nice day!
alanjt
  • Standby for witty remark...
« Reply #4 on: December 22, 2011, 10:13:44 AM »
Snap to the midpoint of the top of the image.
Dropbox
M-dub
« Reply #5 on: December 22, 2011, 10:39:32 AM »
Command: move
1 found
I told him an even easier way. :)
turn the frame on (IFRAME) and move it using the midpoint of the top frame to its destination...
« Reply #6 on: December 22, 2011, 10:57:09 AM »
the actual 'lesson' therein is that one may use parts of the Image Frame to locate the image using normal object snap modes
alanjt
« Reply #7 on: December 22, 2011, 11:01:16 AM »
Just leave the imageframe variable set at 2.
Dropbox
Matt__W
  • I like my water diluted.
« Reply #8 on: December 22, 2011, 11:02:13 AM »
+1
Autodesk Expert Elite
Matt__W
« Reply #9 on: December 22, 2011, 11:03:48 AM »
Make a dynamic block out of it with MULTIPLE insertion points.
For when he changes his mind later on.  :)
alanjt
« Reply #10 on: December 22, 2011, 11:07:01 AM »
:-D
Dropbox
« Reply #11 on: December 22, 2011, 11:08:52 AM »
there is no need to make a block out of it from where I'm typing
M-dub
« Reply #12 on: December 22, 2011, 11:09:11 AM »
+1
+1more
He wasn't talking about one specific image... just ... any image.
alanjt
« Reply #13 on: December 22, 2011, 11:15:35 AM »
I think you'd be better off slapping him across the back of the head and showing him all the options OSnaps offers.
Dropbox
M-dub
« Reply #14 on: December 22, 2011, 11:17:21 AM »
Pretty much...
