Author Topic: ABC's of AutoLisp--Protected Symbol error  (Read 2486 times)
Jeff H
« on: April 14, 2011, 03:40:23 AM »
Usually when I would look at Lisp it would make me make a face like when you smell a bad fart.
But after reading a litte more than half of this http://klobouk.fsv.cvut.cz/~chour/Lisp/Contents.htm
it seems like it would be fun to play with
and I am sure you all have read it
but it is a great primer as I can start to understand some of the code that is being posted.
Anyways I decided to try some of the code and my first expirence with AutoLisp I keep getting a message box with AutoCAD 2012-32bit
"Assignment to Protected Symbol
Last:
Enter breack loop"
What would be protected?
(defun C:SEQ (/ pt1 currnt last)
  (setq pt1 (getpoint "\nPick start point: "))
  (setq spc (getdist pt1 "\nEnter number spacing: "))
  (setq currnt (getint "\nEnter first number: "))
  (setq last (getint "\nEnter last number: "))
  (setq stspc (rtos spc 2 2))
  (setq stspc (strcat "@" stspc "<0"))
  (command "text" pt1 "" "" currnt)
  (repeat (- last currnt)
    (setq currnt (1+ currnt))
    (command "text" stspc "" "" currnt)
gile
  • Marseille, France
Re: ABC's of AutoLisp--Protected Symbol error
« Reply #1 on: April 14, 2011, 03:56:36 AM »
'last' is a native LISP function (which returns the last item in a list).
As the 'last' variable is localized, it's only redefined within the routine.
Using the VLIDE should help you with the color syntax (last should display in blue).
Jeff H
« Reply #2 on: April 14, 2011, 04:02:57 AM »
Thank you gile,
That was it.
I was reading the error as enter last break loop
It was right there in my face.
