Code Red => AutoLISP (Vanilla / Visual) => Topic started by: HasanCAD on October 04, 2010, 10:33:38 AM
Entmake without text alignment working good
(entmakex (list
(cons 0 "TEXT")
(cons 1 LyrName)
(cons 7 "LyrNameTxt")
(cons 8 LyrName)
(cons 10 Pnt2)
(cons 40 220)
(cons 41 0.8)
(cons 62 LyrClr)
but when try to add dxf code for alignment the text created in 0,0
(entmakex (list
(cons 0 "TEXT")
(cons 1 LyrName)
(cons 8 LyrName)
(cons 10 Pnt2)
(cons 40 220)
(cons 41 0.8)
(cons 62 LyrClr)
(cons 72 0.0)
(cons 73 2.0)
Help please
You must use DXF code 11 for alignment.
Just put the same point in 10 and 11 and it should work.
Text with alignment other than "left" uses DXF code 11 for the location, not 10.
dgorsman
Working
Thanks for the clarity 8-)
