Author Topic: fONTS ... vertical ones  (Read 3472 times)
Hangman
« on: March 29, 2004, 11:27:21 AM »
Would anyone know where I can get a font that I for can write column text ???    :lol:    Ya know, like on the spine of a binder.
« Reply #1 on: March 29, 2004, 12:10:31 PM »
Why wouldn't you use mtext with one letter per line?
V
E
R
T
I
C
A
L
T
E
X
T
C
A
B
Hangman
Using Mtext ...
« Reply #2 on: March 29, 2004, 01:03:22 PM »
Not bad if you have just a couple things to edit.   The difficult part is the 'letter', return, 'letter', return, 'letter', return.   I know, it's not THAT difficult, but doing several, over and over again gets very cumbersome, time consuming and annoying.   A vertical text would make typing a lot faster.   Unless you pick at it like a chicken,   :lol:   then I guess it wouldn't matter.
Dent Cermak
« Reply #3 on: March 29, 2004, 01:33:06 PM »
Open the text style dialog box (Type "ST" or "STYLE") on the command line. Bottom Left corner under "effects" check "VERTICAL". Be sure to create a new style name for this text style, otherwise ALL type in this font will change within your drawinf.
« Reply #4 on: March 29, 2004, 01:46:38 PM »
Dent
I tried that in ACAD 2000 Windows 2000 and the text went up
the screen and the letters were not rotated. As if you selected
a 275 deg angle. Although the book shows vertical text
as he is looking for. :?:  (dtext with shx font)
Hangman
Dent, ...
« Reply #5 on: March 29, 2004, 02:02:32 PM »
Not to mention that w/ 2k4 ADT,  for some reason, not sure why, my selection for vertical font is grayed out.   Will not let me make that selection.   :?
hudster
« Reply #6 on: March 29, 2004, 02:05:29 PM »
works on mine, using romans and mtext.
Kate M
« Reply #7 on: March 29, 2004, 02:29:26 PM »
I don't think TTF fonts support vertical alignment, at least, not all of them.
« Reply #8 on: March 29, 2004, 03:25:11 PM »
Yes Kate..no TTF
In ACAD2000
Vertical
Displays the characters aligned vertically. Vertical is available only if the selected font supports dual orientation. Vertical orientation is not available for TrueType®  fonts.
Perhaps only some shx fonts support vertical orientation.
« Reply #9 on: March 30, 2004, 05:17:40 PM »
Hangman
When all else fails roll your own.
http://www.4dautomation.com/Autocad/Makefont.lsp
Instructions are found here.
http://www.cadresource.com/library/fonts.html
