Author Topic: editor.command()  (Read 5644 times)
sybold
editor.command()
« on: November 19, 2014, 11:23:21 AM »
why does this code work
        <CommandMethod("TestSimple")> _
        Public Shared Sub TestSimple()
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            'call Editor.Command to send command directly
            ed.Command("Line", "0,0,0", "10,10,0", "20,50,0", "")
and this won't, getting einvalidinput
       <CommandMethod("TestSimple2")> _
        Public Shared Sub TestSimple2()
            Dim savepath As String = "c:\temp\output.zip"
            ed.Command("-etransmit", "c", savepath)
BillZndl
Re: editor.command()
« Reply #1 on: November 19, 2014, 12:07:54 PM »
Everytime I set a file path to a string in C#, I have to use double backslashes.
"c:\\temp\\output.zip"
Might not be it.
sybold
« Reply #2 on: November 19, 2014, 12:18:45 PM »
the path is right, using Commandasync it creates the zip now. but i get a error after its done.
System.NullReferenceException: Object reference not set to an instance of an object.
   at Autodesk.AutoCAD.EditorInput.Editor.CommandResult.Callback()
<CommandMethod("TestSimple3")> _
        Public Shared Sub TestSimple3()
            'call Editor.Commandasync to send command directly
            ed.Commandasync("-etransmit", "c", savepath)
gile
  • Marseille, France
« Reply #3 on: November 19, 2014, 01:34:46 PM »
I don't know the VB equivalent for async and await C# keywords, but this works:
Code - C#: [Select]
  1.         [CommandMethod("TEST")]
  2.         public async void Test()
  3.         {
  4.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  5.             await ed.CommandAsync("_.-etransmit", "_c", @"C:\Temp\output.zip");
  6.         }
EDIT: this VB syntax seems to work:
Code - vb.net: [Select]
  1.         <CommandMethod("TEST")> _
  2.         Public Async Sub Test()
  3.             Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
  4.             Await ed.CommandAsync("_.-etransmit", "_c", "C:\Temp\output.zip")
  5.         End Sub
« Last Edit: November 19, 2014, 03:47:49 PM by gile »
sybold
« Reply #4 on: November 20, 2014, 03:19:05 AM »
great!, going to read in this async stuff.
sybold
« Reply #5 on: November 20, 2014, 05:02:39 AM »
as a command it works, but not within a eventhandler
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
   at Autodesk.AutoCAD.EditorInput.Editor.CommandAsync(Object[] parameter)
Private async Sub docs_DocumentCreated(sender As Object, e As DocumentCollectionEventArgs)
        If (e.Document Is Nothing) Then
            Return
        Else
            AddHandler e.Document.Database.BeginSave, AddressOf Database_BeginSave
            AddHandler e.Document.Database.SaveComplete, AddressOf Database_SaveComplete
            If e.Document.Database.OriginalFileName.EndsWith("dwt") Then
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "New Document Created - " + e.Document.Name & vbLf)
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "Used Template - " + e.Document.Database.OriginalFileName & vbLf)
                If e.Document.Database.OriginalFileName.Contains("VSH_Template_") Then
                   ''' load form for customproperties
                   Application.ShowAlertDialog("NEW Drawing with vsh template!")
                End If
            Else
                ''' load form ýes/no backup
                    ''' if yes
                    ''' backup drawing with xrefs
                    Await e.Document.Editor.CommandAsync("-etransmit", "c", "c:\temp\output.zip")
                    ''' Application.ShowAlertDialog("backup created!")
                    ''' else
                    ''' Application.ShowAlertDialog("no backup created!")
            End If
        End If
BlackBox
« Reply #6 on: November 20, 2014, 08:37:13 AM »
Correct; your event handler is attempting to call a command in Application context, which is causing the exception... For that you might instead consider using SendStringToExecute().
Cheers
