I'm trying to post the create date in an attributed title block, but I need it in upppercase..
I have before inserted a field with the create-date.. very easy.. but now I need it in uppercase.
I can't seem to achieve this through the field editor
I have tried this diesel expression, but it returns some other date FEB 23, 1996
easy enough to change the code to post the whole month, but it's posting incorrectly..
I have no idea where that date comes from, but it's not the creation date of the DWG.
d-expression
$(upper,$(edtime, $(getvar, tdcreate),MON. DD YYYY))
tdcreate = creation date??
is there a different variable?
I have tons of dwg's it's rediculous to type this in on every one..
the plan was to fix this in the title block then drop in the revised title block to each of the files. I could script this.
-Suggestions.. Ideas?
