Author Topic: 2 or 3 centered curves - LISP or VBA?  (Read 5924 times)
Leafrider
Re: 2 or 3 centered curves - LISP or VBA?
« Reply #15 on: February 14, 2011, 11:35:12 AM »
After reviewing this further, I do appologize for not clarifying these values in greater detail earlier on. The type of design vehicle determines the offset value. You can find tables within the AASHTO - Geometric Design for Highways and Streets (pg. 589). I've attached the document from the TAC manual, table isn't attached.
The easist way to define this "symetrical offset" value would be to prompt the user for a value, if no default value is chosen (enter) than default to 3.0 meters (value for a WB 20 @ 90degress). Hope this helps.
did.ave
« Reply #16 on: February 14, 2011, 11:46:23 AM »
coucou
thank you for these explanations, I'll watch but I lack free time.
I can send the new version in progress?
amicalement
SOFITO_SOFT
« Reply #17 on: February 15, 2011, 08:57:28 AM »
coucou
I'm working on a new version but I want to know precisely what that value "O" ?
I still do not know what it is exactly.
angle, dimension, tangent ...<<<<<<  as it is drawn is a longitudinal dimenion
soon on The Swamp
amicalement
Greetings
